Steering assist
Discussion in 'Off Topic Hot Rods & Customs' started by Dennis and Tammy, Jun 25, 2025.
  1. Thanks to all for for the advice on the 50 Merc. Running smooth as silk. With both my old Mercs 49-50 we are dealing with more steering play than is comfortable. Have tightened the worm gear and seems like no real play at the wheels. What elec steering ***ist would work on these units? I’d like to upgrade the wifes 49 so she is more comfortable driving it
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved to the off topic forum. Electric power steering is off topic on the main forum
  3. miker98038
    miker98038
    Search EPAS. Should get some results in the social groups and other forums. I’ve seen it discussed on both the Ford Barn and yblocksforever. I’m not on the earlier boards where your 50 would be.
  4. mustangsix
    mustangsix
    lostn51 likes this.
  5. 1biggun
    1biggun
    I have seen Prius steering used .
    As I recall two wires to make it work
    I'd do some Google searching.
    I was half *** thinking of sticking one for in the middle a non original messed with column in my 57 Vette. .
    I think there is a gm steering motor that uses a simple circuit board that might give a bit better feel.
    This is a thread I'll be following as my Vette with a quick steer addapter and a bit wider tires steers very heavy.
    lostn51 likes this.
  6. pprather
    pprather
    Before working on power steering, the original steering box needs to be repaired or replaced.
    Power ***ist will not fix the excessive 'steering play' that you described.
    lostn51, rockable and Moriarity like this.
  7. gene-koning
    gene-koning
    That is absolutely true. Fix the worn out box first.
    I've seen a couple of really well written build processes where electric power steering has been installed, but I can't think of where that was. Maybe it is buried in the archives here!
  8. Ned Ludd
    Ned Ludd
    It would help to know the steering ratio. I believe stock Mercury was around 18:1? — relatively quick for a heavy American car of the era. The slow steering typical of that type of car often served to mask play at the steering wheel. For instance, 10° of play at the steering wheel translates to barely more than ½° at the front wheels.
    If you are looking to keep the stock steering ratio, you won't need a lot of ***ist to achieve finger-light steering. There, electric ***ist may or may not offer the opportunity to fine-tune the level of ***ist it adds, depending on the hardware you choose. However, adding ***ist opens up the possibility of going to quicker steering. If the ***ist is flexible and acts on the steering column, that would remain an option in the future.
    Quicker steering makes play more perceptible, which is why modern quick power steering is almost universally based on precise rack-and-pinion steering. I believe some recent Toyotas have used what are basically quick manual racks driven by column-mounted steering ***ist.
  9. 1biggun
    1biggun
    I read that he had adjusted the box and removed the play in the opening post and was looking at options and how to add electric PS ***ist not fix loose steering.
  10. 1biggun
    1biggun
  11. 1biggun
    1biggun
  12. 1biggun
    1biggun
