Technical Steering box for a 57 ford
Discussion in 'The Hokey Ass Message Board' started by 57countrysedan, Apr 14, 2014.
  1. 57countrysedan
    57countrysedan
    from NY
    Need to rebuild/replace the steering box in my 57 ford wagon. Manual steering. Any body know if another box will fit or a source to get another box? Im sure i can rebuild it its just id have no where to keep it when i have it all apart. I saw the Borg boxes that convert to power steering but id rather just keep it the way it is. Thanks guys
  2. seb fontana
    seb fontana
    from ct
    I think I may have one or at worst don't remember what I did with it..Was rebuilt so worth a look...PM me in a day or two..
  3. 57countrysedan
    57countrysedan
    from NY
    Thanks for your help before. Wish there was another box i could just put in
  4. seb fontana
    seb fontana
    from ct
    I think 55 & 56 may interchange as far as box bolting in place but I don't know if the columns will mix..
  5. fordor41
    fordor41
    Lares Corp. will rebuild it you want to go that route. (763) 691-1400
  6. 57countrysedan
    57countrysedan
    from NY
    Okay thanks. Goin to save that number for sure. And I'll look into the 55-56 if i can find one. Thanks again guys
  7. big M
    big M
    The '57 steering box was a poor design, they went to the recirculating ball type in '58 which was far better. I would consider using one from a '58, although you will need the mast jacket also as it's slightly different. The '58 unit will bolt in exactly the same though.
    ---John
  8. 57countrysedan
    57countrysedan
    from NY
    Thats good to knw. I was suspect of that myself since i heard somewhere that they changed the box. Goin to keep trying to find something. I appreciate all the help guys!
  9. Jeff Norwell
    Jeff Norwell
    MODERATOR
    No.They do not interchange.
    When using a 58 box… not sure if the splines will match. A lot of guys then use the whole column as well from a 58.Bolts in directly.Then…using a 58 box and column.. your horn will not function.I believe a direct swap is a 63 galaxy unit..I will go check that info...
  10. 57countrysedan
    57countrysedan
    from NY
    Thats cool! Just did a quick google search and saw some stuff on 57 ford forever talking about this. Goin to do a lil more homework on it. Let you know what i find. As far as using a 58 column and box im in the same boat since its hard finding old parts near me. Thanks again everyone!
  11. tommy
    tommy
    If you want a direct bolt in you will need a 57-58 box. I tried to use a 57 mast housing on my 58 Ranchero and the mast was 1/2" from the steering wheel. 57 was weak box that got upgraded to a much better box in 58. If you can find one replacing it with a complete 58 box and mast is the best option. You'll be better off with a 58 than rebuilding the 57. The systems interchange but the parts for each column do not.
  12. 562roadster
    562roadster
    I may have a whole column & box from a 59 wagon. Pm me and i will see if i do
