Steering box grease
Discussion in 'The Hokey Ass Message Board' started by butch27, Jul 15, 2008.
  1. butch27
    butch27
    What's a good mix to use in a '56 Ford truck steering box? Nothing too runny?
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Orignaly 90W . If it is a leaker a lot of people put in ch***is grease. Another thread lately said STP or Lucas which would be better than grease.
  3. daveyboy56
    daveyboy56
    Do lucas and stp 1/2 and 1/2 will not leak and works well
    Dave
  4. VAPHEAD
    VAPHEAD
    600w
    any old Ford place carries it.
  5. Terry O
    Terry O
  6. rustyford40
    rustyford40
    from Mass Bay
    I used stp in my 54
  7. gasheat
    gasheat
    from Dallas
    Fill it FULL of wheel bearing grease and forget it.
  8. I would not reccomend wheel bearing grease. It does not flow. For what it is worth some of the guys on the Falcon website really like John Deere cornhead grease. It is plenty thick and comes in a grease gun tube so it is esay to get into the box.
  9. TagMan
    TagMan
    I'll second the J-D cornhead grease. Thick, but flows well.
  10. man-a-fre
    man-a-fre
  11. Gear oil may run out with the seals no longer being perfect. I'd drill a hole somewhere safe, screw in a Zerk fitting, and pump in some ch***is grease until it started oozing out somewhere. I've even done this to my 38 Chevy vent window gear boxes:cool:
  12. Chevy Gasser
    Chevy Gasser
    I'm surprised the guys from the northeast even know what John Deere cornhead grease is, but yes, they are right on. Kind of a cross between ch***is grease & 90 weight gear oil.
  13. 4 2 GO
    4 2 GO
    Shell makes some Semi-solid Grease that is ideal for this. It looks like ch***is grease but actually flows (slowly) but does not run like 600W.
  14. tommy
    tommy
    We used to make our own at the shop I worked at many years ago. Good old wheel bearing grease and 90 wt gear oil mixed in a coffee can until the desired consistency is reached. Thick but fluid enough to flow back between the gears.
  15. HotRodJosh
    HotRodJosh
    At least I'm not the only one that has done this!
