Hot Rods Steering box help
Discussion in 'The Hokey Ass Message Board' started by V4F, Jan 23, 2013.
  1. V4F
    V4F
    from middle ca.
    i have a stock model "A" steering column , what steering box will be the easiest to use with the stock column ??? thanks .. steve
  2. F-1 or F-100 is a pretty easy fit.
  3. V4F
    V4F
    from middle ca.
    ok , who sells them ? thanks ....
  4. ironfly28
    ironfly28
    from Orange, CA
    The Model "A" steering box will be the easiest to use with your Model "A" steering column. or hoe bout a 32-34 box? rebuilt it works just as good and needs less mods than an F-100 box to fit in your a rails.
  5. V4F
    V4F
    from middle ca.
    i have suspension changes tha makes the stock box damn near impossible to use ...... thanks .. steve
  6. Look in the classifieds? look on craigs list or the junk yard? The same people that will sell you a '33-'34 or a model A box are the people that sell F-1 or F-100 boxes.
  7. ironfly28
    ironfly28
    from Orange, CA
    perhaps a corvair box will suit you...........Are you running an IFS?
  8. V4F
    V4F
    from middle ca.
    thanks for the info . corvair i havent thought about ... hmmmmmmmmmmm .. steve
  9. Would you like to elaborate on the build? HRP
  10. V4F
    V4F
    from middle ca.
    just a model "A" coupe . 4" drop axle , hyd brakes , hair pins all around . i may have it figured out . not sure yet . thanks
  11. Andy
    Andy
    Just put a Vega in it and run cross steering. Much easier than modifing truck boxes and trying to rebuild them. You can put a bearing and a U joint at the base of the column and you are set.
  12. V4F
    V4F
    from middle ca.
    yes my first thought . i think i may have come up with a fix . if not vega it is . thanks all for the help ........... steve
