I have a 58 chevy 1/2 ton truck steering box in my vehical. I just messed with resting the lash, and all seems better, but it's lowish looking on fluid. The old GM manual says to use a Grade 0 lubricant? with low cold test characteristics and extreme pressure properties? WTF is that? http://chevy.oldcarmanualproject.com/gmc/5559mm/5559mm509.html It's on the bottom of the page. I'm guessing it's something simple/normal?
http://www.matweb.com/search/datasheettext.aspx?matguid=c85f95a23ac1450a8878f86a097a8080 Explanation here: http://www.agriculture.com/machinery/tools/shop-tool/sting-out-grease-selection_246-ar21522
John Deer Cornhead grease is #00. Self leveling (Thin)...and recommended on the stovebolt forum. Just a thought. And...I need to type faster. Oh, this just in...Shell Alvania EP 1 Grease 2041SIPA
"John Deer Cornhead grease is #00. Self leveling (Thin)...and recommended on the stovebolt forum." Been using that stuff for years and it works great.
ditto on the cornhead grease. Try to get as much of the old stuff out of there as you can before you put the good stuff in.
Put any kind of lube in it that you want and check the steering effort. Then drain it and refill with straight PowerPunch or STP. Then check the steering effort. You will think you have power steering.
Depends on how good the seal is and what condition the pitman shaft is in. If both are in really good shape, then a liquid type lube will work. If they are worn, corn head is grease is a better option. The grease will self level after a bit yet not run out the seal. Corn head grease is also under $3 a tube at most any John deere dealer. One tube will do a normal gear box.
i have used Penrite too good stuff but expensive. it is sort af a mix of oil and grease. it is good for alot of other things too. i tried STP but it will leak out eventually.
We used to make our own by thinning wheel bearing grease with 90 wt gear oil in a coffee can. ( stocked items) You want a consistency that allows the grease to flow back when you drag a screwdriver through it as you mix it. Too thin and you will get leaks, too thick and the grease will not flow back between the gears as you turn.
