Steering box mounting ????
Discussion in 'The Hokey Ass Message Board' started by socal_wrench, Jun 19, 2006.
  1. socal_wrench
    socal_wrench
    I had to relocate the steering box on my A, and thought I would ask before I remount it.
    I have a 39 Merc. cross steer boxwith the steering arm that is angled up.
    What is the correct way to mount it?
    With the arm parrallel to the floor or the shaft perpendicular with the floor, Which would make the ends of the arm parrallel and the arm itself going upwards. I guess I should get pics of this I will do so im a couple of minuites
  2. socal_wrench
    socal_wrench
    Crappy pic.
  3. Killer
    Killer
    I always worry more about the angle of the steering column!
  4. Bruce Lancaster
    Bruce Lancaster
    Stock mounting is with box slanted, putting the arm roughly parallel to the world. Shaft perpendicular to world would have put the wheel under the seat in the Merc...
  5. socal_wrench
    socal_wrench
    Thanks Guys
    Mucho Grassy-ass.
  6. Candy-Man
    Candy-Man
    The tie rod bar and the drag link bar should be parrallel to each other and on the same level. You may bend the pitman arm on your steering box in the same fashion as steering arms are heated and bent on Ford spindles to clear wish bones, etc... Try not to have the pitman arm facing on an angle, downwards, as if it would dig into the road if you hit a bump...Hope this helps....
