Hot Rods Steering box problems
Discussion in 'The Hokey Ass Message Board' started by Mike Colemire, Apr 30, 2023.
  1. Mike Colemire
    Mike Colemire
    I have a 69 camaro manual steering box I'm using on my project. It was a little rough feeling so I pulled it apart and water had got in it. Ordered a kit and the bushing and seals are the same but the end cap won't screw on but about one thread. It acts like the new bearings and race are to thick, plus the bearings look cheap and have a plastic cage. Anyone know where I can just get the bearings and race?
  2. squirrel
    Tow Truck Tom likes this.
  3. Mike Colemire
    Mike Colemire
    Thanks, that looks like what I need, ill do a little more research on the specs. I was thinking several manufactures used these same bearings but I could be wrong. It's been awhile since I done this.
  4. squirrel
    The link to bearingsdirect has several interchange numbers.
    ottoman likes this.
  5. willys36
    willys36
    Why can we talk about '69 parts?
    2OLD2FAST likes this.
  6. seb fontana
    seb fontana
    from ct
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Or ford 8.8" or rack & pinion steering or any mul***ude of " later than ' 65 "parts .? Ask the source , bound to be some mumbo jumbo available ?
  8. squirrel
    they fit Chevys back to 1961, too. Same bearings that are in my Chevy II.
    PONTNAK123 and 19Eddy30 like this.
  9. willys36
    willys36
    Just asking because one mention of a M**
  10. Mike Colemire
    Mike Colemire
    It's going on a 57 chev if that makes a difference. I've found several out of stock ones, got a few emails out there waiting to hear back.
    Budget36 likes this.
  11. andyh1956
    andyh1956
    You building a Straight Axle settup?
  12. Mike Colemire
    Mike Colemire
    I'm going to a straight axle later, right now lm just going to get it running and driving. I seen a build on here where a guy put a vega box on his 55 so I'm doing it with this box, don't like the vega box on a heavy car.
  13. dan c
    dan c
    if the old bearings have numbers on them, you might try a bearing house for replacements.
  14. Mr48chev
    That box was "thee" manual box for the majoity of 64 GM mid or full size p***enger cars with a manual box. How the hell it is going to work in a 57 Chevy without a lot of mods is beyond me though.
    Top being the 64 ElCamino box aka 69 Camaro box bottom being the 57 box without half the steering shaft showing. The late box isn't going to fit where the early box did and I don't think there is room to move it forward for cross steer on the 57 frame without a lot of cutting. Screenshot (1512).png 57 Box used.jpg
  15. Mike Colemire
    Mike Colemire
    The guy that done the vega box made his own mount, dropped it down and used the ball out of the 57 pitman arm and installed it in a dropped pitman arm. I'll try to find the build thread. Anyway, the casting # on my box is 5678142, no number on the bearing race, first thing I checked.
  16. Mike Colemire
    Mike Colemire
    55 chevy 2 dr sedan by Larry T. It's in the build threads. Wether I use this now or when I put the straight axle in, I still need bearings. The closest thing I've came up with on the casting # is a 69 z28 with the casting # of 5679142.
