Hot Rods steering box question
Discussion in 'The Hokey Ass Message Board' started by DROPnDRIVE, Sep 27, 2008.
  1. DROPnDRIVE
    DROPnDRIVE
    from New Jersey
    OK, so I found a pretty good deal on a 55-56 chevy steering box and column, I was just wondering if anyone knows whether or not it needs to be reversed to be used for cowl steering? I would go check it out, but of course its hlaf way across the country...
    thanks for the help!
  2. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Idk...but BTT for my brotha! :D For the night crawlers!
  3. Dale Fairfax
    Dale Fairfax
    Yes, it needs to be reversed. I've done several of them, but my version is "enhanced". I saw all the mounts off the case then put it in the lathe and turn the pitman shaft housing so it's smooth and round. The gear then looks a bit "racier". I also replace the big threaded plug (the one that adjusts bearing load on the steering/worm shaft) with a special aluminum piece that adds support to the shaft and provides a surface to mount a mast jacket to. To hang it in the car, I make mount that looks like the big end of a con rod that clamps around the (now round) pitman shaft housing.
  4. DROPnDRIVE
    DROPnDRIVE
    from New Jersey
    wow...haha thats pretty frikkin involved there man! thanks for the reply/advice! guess I'll keep hunting down a good deal on one of those Mopar boxes!
