Hot Rods Steering box what is it ?
Discussion in 'The Hokey Ass Message Board' started by marc billen, Dec 19, 2020.
  1. marc billen
    marc billen
    from lakeside
  2. Looks like F100
    Mr48chev likes this.
  3. Boneyard51
    Boneyard51
    That’s my guess also!
    Bones
  4. Looks like a 48-52 F1 box
    flatford39 likes this.
  5. Mr48chev
    F100 The worm gear on an F100 is above the sector shaft when the box is mounted to the frame. Worm gear is below the sector shaft on an F-1. F-1 uses a nut to hold the pitman arm 53/56 F100 uses the pinch bolt.
    Top being F 1 bottom being F 100 with a chopped off steering shaft. F 1 box.jpeg 1953-1956-ford-f100-complete-steering-box.jpg
  6. ct1932ford
    ct1932ford
    The box on the first post looks like a 57- 60 f100 pitman arm is from a 57-60 f100 box.
    I changed this post because I was talking about the 48-52 box posted above. Now that we are all screwed up I will go to bed.
  7. X38
    X38
    Can't both be right.:eek:
    Re. pitman arm, the pinch bolt 53-6 versions had a ball for the tie rod yes?
  8. alchemy
    alchemy
    Yes the pitman is F-100, from 1957 and later with the tapered small end. The box is probably 53-56, because I think the mounting flange got bigger in 57, right?
    No F-1 (anything pre-53) parts there at all.
    X38 and Andy like this.
  9. Andy
    Andy
    Correct
    X38 likes this.
