Steering Column install in 1932 Ford
Discussion in 'The Hokey Ass Message Board' started by speedfreak1976, Jun 20, 2012.
  1. speedfreak1976
    speedfreak1976
    Hey guys,I built a 1950 Chevy truck on an S10 frame and got the bug to build another car. I bought a 32 Ford 5 window project car today. I have a couple questions on the build. I need to buy a steering column. What fits good? I want tilt GM or should I buy a Flaming river one or a stock GM one?
    Whats the normal amount of column drop do people use on a 32 coupe?
    Any opinions are welcomed, I am new to this 32 Ford world. Let me know. Thanks P.S. This car has a vega box with a dropped front tube axle if that matters on the column choice.
  2. harleycontracter
    harleycontracter
    I bought mine from Borgensen in CT . Thought it was a great price. It's just a steering column.
    Check your messages
  3. lowsquire
    lowsquire
    from Austin, TX
    Limeworks makes a great original looking column that will work with your set up.
    Steve who runs the place is a champion, and if I can head your business his way, all the better.
    http://limeworkspeedshop.com/
    My opinion is that big fat tilt columns, aftermarket or O.E. look ****ing terrible in a hotrod. Well, you asked.
    Olcars likes this.
  4. nwbhotrod
    nwbhotrod
    from wash state
    You Sir are so right
  5. uncle buck
    uncle buck
    What he said
  6. speedfreak1976
    speedfreak1976
    So do you guys use those clamp on turn signal mounts on the columns or what? i was hoping to get one that had the turn signal built into the column. Someone told me a while back that a early chevy van column fit. I really dont like the look of those clamp on turn signal things. Whats my options here?
  7. bangngears
    bangngears
    from ofallon mo
    Put the turn signal down past the column mount or under the dash out of site.I mounted one vertically under the dash,i can get to it and its out of sight.No fat columns!
  8. A Boner
    A Boner
    I happen to like the old time look of clamp on turn signals. They are an easy way to get the brake lights to cancel out, when the signal is flashing. As for the late model Detroit columns....I personally think they look like ****. The best is finding an old clamp on, but even the new clamp ons look way better than a fat van column.
  9. BAD PENNY
    BAD PENNY
    from mass
    Here's a shot of the Hot Rod column from Lime Works in my coupe. It had a fat GM tilt column in it. I highly recommend them !!! Top notch product.
    I almost forgot...I'm going to use an electronic turn signal from Speedway. Part #910-64070.
    I guess they use them on motorcycles. You need a momentary on-off-on toggle switch.
  10. NealinCA
    NealinCA
    One option for intergral turn signals is to use a Mid-50's Ford or GM column. I used a 54 Chevy car column in my 49 GMC pu...
    It has self cancelling turn signals...but isn't a fat late model column.
    Mid to late 50's Ford pickup columns are 1-1/2 column tube like early Ford, but have turn signals.
    I still used a clamp on turn signal switch in my 32...because it's 40's style and I didn't want to use a 50's column. But with a later style build I would sure consider a 50's column.
    Neal
  11. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Traditional build requires an era-correct column (and everything else for that matter). No Flaming nothing. A real-deal Ford column (or a Limeworks column) is all that's acceptable. And no steenkeeng billet or sports car steering wheel either.....or we'll find you and kick your ***!!!! :)
    BettyBlue likes this.
  12. Deuce Roadster
    Deuce Roadster
    Here is a Chevy/GMC van tilt column with the shifter on the column in a 32 Ford roadster ( not mine )
    Not big, bulky or fat looking in my opinion :D
    The Limeworks column is beautiful but ... if you are 190/200 lbs or more ...
    the tilt comes in real handy.
  13. speedfreak1976
    speedfreak1976
    what length are you guys using if I buy the limewire. I think I saw a 30,32, and 36 length. Sorry but this stuff is all new to me
  14. jmikee
    jmikee
    from washington
    I put a chevy van column in a 5 window and found that i never used the tilt because the drop was right and no problems getting in or out.
