1952-59 Ford steering column removel
Discussion in 'Off Topic Hot Rods & Customs' started by Landmine 55, Dec 20, 2014.
  1. Landmine 55
    Landmine 55
    from So.Cal
    Hi everyone I'm trying to remove the steering column out of my 55 I have all ****** linkage disconnected and I loosened the pinch bolt/clamp on the bottom of the column where it meets the gearbox, I can get it to slide about a inch or so then it stops is something I need to remove in the steering wheel? Thanks guys
  2. NMCarNut
    NMCarNut
    The steering shaft is part of the steering box and does not remove without dis***embling the box. If you do not want to remove the steering box, along with disconnecting the shift levers and dash bracket you will have to remove the steering wheel.
  3. Texas57
    Texas57
    These don't come out thru the firewall as a complete unit as on the '57's?
  4. NMCarNut
    NMCarNut
    Yes they come out pretty much the same. Although having recently pulled a steering box and column out of a 56, with the engine and exhaust in the car it is a pain in the rear.
  5. Landmine 55
    Landmine 55
    from So.Cal
    Thanks NMCARNUT I'm just trying to get the automatic shifter shaft from the column I have a 5 speed I'm putting in the car plus I know someone who needs shaft , I'll pull the wheel and remove the shaft that way I just figured I could remove the column and clean it up and re-paint it
