Steering column
Discussion in 'The Hokey Ass Message Board' started by Bondobob, May 22, 2007.
  1. Bondobob
    Bondobob
    I'm running a Fat Man front end which uses a late model Ford rack and a Ididit column in my 57 Chev pick up. The u-joints I got for the column are both solid. Now that I have them ($78 each) I'm thinking I should have gotten one with the anit-vibration rubber or a slip joint style. If both ends are rigid and the frame/body interface moves a little won't it bind up? The frame is completely boxed but the cab will be on some rubber. Thanks.:confused:
  2. UPSrodder
    UPSrodder
    Had the Mustang II rack on my 42 for around 16 years now and never had a problem with binding or vibration. Just make sure the joints are in "phase" and it will be fine. Movement or flex in the body to frame should not be a problem, unless you plan on going 4 wheeling over some rocks and getting everything all twisted..
  3. There is usually a little bit of flex in the floor and the dashboard to allow a slight amount of movement between the body and frame. I haven't had any problems with setups like that myself. With the u-joints out of there, you could try grabbing the steering wheel with both hands and pulling and pushing on it. If you can budge it 1/8" or so by flexing the dash and firewall sheetmetal, then that should be enough flex I think to take up any movement in the rubber body mount bushings. Sometimes the steering shaft up through the column has a little bit of play too which will help. Unless the rubber body mounts are totally shot, they're usually pretty tight.
  4. Bondobob
    Bondobob
    Thanks guys, I feel better now.:D
