Steering Column
Discussion in 'The Hokey Ass Message Board' started by 57tony31, Sep 23, 2009.
  1. 57tony31
    57tony31
    from Woods
    Can anyone tell me who makes this Steering Column . The pin that holds the wheel on the ball and spring fell out looking for a new pin. The shop i pick this up from is no more.
  2. Slonaker
    Slonaker
    It looks like the column I got from Speedway.
    Slonaker
    EDIT: Look at quick release pins at McMaster-Carr. http://www.mcmaster.com/ Maybe check with Fastenal locally?
  3. roughidle
    roughidle
    from iowa
    I would check with speedway.
  4. Tony, sure looks like a Speedway, give 'em a call
    Don
  5. 5window
    5window
  6. Vance
    Vance
    from N/A
    When I bought the Speedway column, it came with a pin like you described and it too had the ball and spring that had fallen out. I called them and they had one at my door in two days; before I even had a chance to install it. Call them. Even if it's not theirs, I'll bet they'll hook you up with one for a fair price.
    Vance
  7. 57tony31
    57tony31
    from Woods
    Thanks alot all and Vance they are sending one out for free. Cant beat that but i may go with a nut and bolt there sending to.
  8. Vance
    Vance
    from N/A
    I actually took a matching size Allen head bolt and nut set and taped it to the steering column down out of site just in case I lost the pin. Never needed it, but it was there if i did... Cheap mental insurance.
  9. doctorZ
    doctorZ
    speedway indeed. limeworks makes one that is very similar, but a bit cleaner. i would check them out!
