steering columns drop pics
Discussion in 'The Hokey Ass Message Board' started by jlow, Jun 25, 2009.
  1. jlow
    jlow
    please post some pics of home made or bought ...thanks
  2. Fenders
    Fenders
    Dunno, this what you want to see? Upper drop is the stock 30 tank drop, lower on the firewall is a late 31 bolted to the firewall. Column is exhaust pipe...
  3. millersgarage
    millersgarage
    I bead rolled, the bent the edge back, and made a curved section for the bottom. The column is inside the tube, making it look like the column is welded to the drop
  4. Mr48chev
  5. Canuck
    Canuck
    Working on a 30 A coupe. Started out with this for a column drop --- [​IMG]
    and ended up with this ---
    Whittled out of a piece of 1" steel stock. I guess that makes it billit :eek:
  6. NealinCA
    NealinCA
    Wow! That is cool. Looks like something that belongs in an old Ford...
    Great job.
    Neal
  7. jlow
    jlow
    wow that is purty..i need one like that thats what i want it to look like ,,,
  8. Deuce Daddy Don
    Deuce Daddy Don
    Here's my home made steering drop.----------Don:D:D
  9. no kidding Canuck, that is awesome!
  10. HotRod33
    HotRod33
    Very nice work.....
  11. bigtumtum
    bigtumtum
    Canuck! is that made with cnc or hand?
  12. It's been a while, but there's another steering column pics thread from a couple years back.
    Nothing wrong with leaving this one up.
    I'm sure some new stuff will surface.
    Canuck, well done.
    Lots of filing, grinding etc. after the machining I'll bet.
    Would make a great tech article if you have the pics.
  13. This is a home made drop by Kirk Duquett in his Woody '32 roadster pickup.
  14. full house Mouse
    full house Mouse
    Nice job!
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  15. SB5332
    SB5332
    from NEW YORK
    MoutAin motor conn rod. Says 426 one side hemi other side. MADE THE DASH INSERT FROM A PIECE OF SEWER PIPE AND HOLE SAW PLUGS. MAYBE I SHOULD DO A TECH ON IT?
  16. Canuck
    Canuck
    Sorry, no pics of the process.
    Tools utilized: a drill press, a old made in Tiawan one that goes down to 270 RPM, a angle grinder and files and lots of time.
    So it doesn't take a fancy shop for anyone to make one or great machinest skills, just lots of determination and some time. Just remember to measure carefully cause you can't just re-run the CNC program and do it again.
    Canuck
  17. skunx1964
    skunx1964
    :eek: wow, thats determination!
  18. cball
    cball
    Here is a pic of one I sell/use at my shop. It is cast aluminum, made by a local m***achusetts craftsman.
  19. srosa707
    srosa707
    from Sacramento
    here ya go
  20. jlow
    jlow
    only problem i have is that my column is way lower than the factory one so im basically going to have to remove the old one from the tank and put a longer one in place of that ...does the old one need to be drilled out to be removed ??????
  21. srosa707
    srosa707
    from Sacramento
    The 29-29 is factory welded to the gas tank, thats why I ran mine the way it is.
