Hot Rods Steering gear box swap
Discussion in 'The Hokey Ass Message Board' started by iceteacharlie, Nov 22, 2021.
  1. 1930 Chevy truck- I want to replace the original steering box with a power steering gear box- wanting to keep it mounted on the inside/going through the frame to the outside so as to not loose the original look. Suggestions (as well what maybe to avoid)?
    Thanks.
  2. Both Ecklers, and Cl***ic Chevy sell a kit for the Toyota box to fit 55-59 Chevy trucks.It has a adapter plate that allows mounting through the frame.Not cheap,but worth a look to see if it looks like you could do the same.
    LWEL9226 likes this.
  3. Early 80s 2 wheel drive pick up has a power steering box that fits nicely . 20180226_213200.jpg
    Tough to see the box but great fit on my 34 chev truck
    irishsteve, Jrs50 and Algoma56 like this.
  4. @wood remover, I would really like to see a better picture of your set up.
  5. Thanks irishsteve and wood remover. Here are the pics of what I've got.
  6. Here are some pictures ,appears the box is an 83 has to be 2 wheel drive pick up .If you can find the pump with it ,they are small with a remote fill great set up !!!! 20211122_210554.jpg 20211122_210615.jpg 20211122_210827.jpg 20211122_210718.jpg 20211122_210749.jpg
    irishsteve and Budget36 like this.
  7. The box is bolted to the frame from the underside,the last 2 pictures you can see the bolt in the boxed frame .
  8. Hey ice tea check your mail.
  9. LWEL9226
    LWEL9226
    from So. Oregon
    We did one of those Toyota steering box kits on a 1950 F series truck.... Works very well....
    LynnW
    iceteacharlie likes this.
