steering problem model a roadster
Discussion in 'The Hokey Ass Message Board' started by breal, Jan 3, 2008.
  1. breal
    breal
    from so cal
    i built a beefy frame and have a all steel roadster 29...is it too heavy to use a reversed corvair..or any other suggestions have to stick to traditional style steering..thanks
  2. chaddilac
    chaddilac
    Nope, that's one of the typical steering boxes everyone uses for model a's.
  3. bonesy
    bonesy
    I used this set up with no problems on my A coupe. The box even polished up nice too.
  4. breal
    breal
    from so cal
    is there a better box to use
  5. AnimalAin
    AnimalAin
    Vega. Compact, available and effective.
  6. Mr48chev
    If you are intending to run a traditional drag link I would say run the Corvair style box. If you want to run a cross steer setup run the Vega style.
    It is recommended that one runs a panhard rod when using the cross steer.
    The rest of the group will probably come up with some more ideas pros an cons for each.
  7. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Some guys use '65-'67 (?) Mustang Boxes for a front to back set up... I'm ***uing that you're not hell bent on "traditional" stuff since your first option was the covair box.
    There are also some late '50's Chevy boxes that would work in a simular fashion, an F1 Ford box, there's plenty of options...
    Or you can go all out anf run a Shroeder steering gear through the side of the cowl.
  8. What is a "beefy frame?"
  9. Kevin Lee
    Kevin Lee
    Super Moderator
    Also, what is a "traditional draglink"?
    Cross steer still uses a drag link and Fords from '35 all the way to '48 were cross steer in stock form. It's the F1 and F100 boxes that were side steer and those boxes were adapted to a lot of hot rods... but there were plenty of cross steer cars out there too. Lately I have seen anything used as side steer labeled "traditional steering" and I consider it a misnomer.
  10. bonesy
    bonesy
    You can see the Corvair box in this shot - it withstood the weight of the iron head 502 over it.
    Not that the Corvair was bad, but on my old '32 I used a Vega - it had much better road manners.
  11. zombo27
    zombo27
    from E-town Ky.
    "Beefy Frame, it's what's for dinner."
  12. breal
    breal
    from so cal
    thanks for the help...and a beefy frame means its made real nice and strong
  13. Why does the type of frame manufacturing makes it too heavy to use the Vega box? I have seen Vega boxes in boxed 32 frames with Hemis , BBC , and FE's sitting in them with no problems.
  14. 392_hemi
    392_hemi
    Vega boxes are not recommended over a certain weight. I think something like 2500 lb. Using one in a closed car with a hemi (or other big block) is probably pushing it.
  15. breal
    breal
    from so cal
    i used thick walled 2x4 tubing its a little heavier than normal thats the only reason,and it has suicide front end
  16. jusjunk
    jusjunk
    from Michigan
    Well then front end pretty much rules out a vega box then.. If i remember right though there were some guys mounting vega boxes on the top of the frame rail and using them.. Ive always thought the corvair boxes were pretty light but then what the **** do i know :D
    Dave
  17. Kevin Lee
    Kevin Lee
    Super Moderator
    I'm confused. Please explain.
  18. Do you have a photo of your frame you can post?
  19. Lucky77
    Lucky77
    Early Mustang like 64-66 works well with the traditional/side steer setup. You mount the box upside down and the pitman arm swings fore and aft from the bottom of the framerail.
  20. jusjunk
    jusjunk
    from Michigan
    Well i just guess it would have to be mounted pretty far forward with a suicide front thats all.. Sorry I thought bout that a little more and it can be done but the box needs to be pretty far forward to keep everything in the right perspective.. Im not a fan of side steering and im not a fan of suicide fronts either but again thats just me:D.. **** C9 is the one getting **** about the beefy frame :D:D.. Me I like beefy cause light weak **** kills..
    Dave
  21. Model A Vette
    Model A Vette
    Has anyone used a Mustang, Maverick or the similar 63-81 Corvette box for a cross steer box?
    This would seem to give more space next to the motor as the gear portion of the box would be on top of the frame.
  22. Fenders
    Fenders
    I have a 65 - 66 Mustang steering box and it looks like it would work fine on my Model A for cross steer. I too wuld like to hear comment from those who have done so.
    I have no clue about using it for side steer as Lucky 77 says, unless it is mounted on the outside (!!) of the frame. Maybe I don't understand....
    fenroo
