steering question...
Discussion in 'The Hokey Ass Message Board' started by 440scout, Feb 18, 2011.
  1. 440scout
    440scout
    from reno nv
    building a tall t .. i was going to run a corvair box.. i reversed it and to make it work properly the pitman has to be faced downward.. the car is so low that if i do that the draglink wil have to be pointed upward alot... or my idea was to run the draglink on the bottom side under the front axle... has anyone done this.. i was noticing that my steering arm would hit the beam on the front so... its a 37 front axle with 40 spindles... is there a steering arm that would accomodate this??
    the other option is to go with a different steering box.. some thing that the pitman faces up ward instead when mounted..
    what do you guys think??
  2. F&J
    F&J
    Old VW bus has the arm pointing up.
    I can't see running the drag link under the axle. JMO
  3. 440scout
    440scout
    from reno nv
    i was lookin at one of those on here too..
    any other options?
    i thought someone had used a toyota box before too..?
  4. Bill Van Dyke
    Bill Van Dyke
    F&J is on the mark. I've used them on hiboys with great results. Gemmer box with frame mounting bracket which lets you set the wheel where you want and gives you a fairly level drag link. You don't have to screw with the steering component geometry either.
  5. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    i kinda like how this volvo 142 box worked out. it has the look of a smaller ford type box. not hard to find. cheap!
  6. Dale Fairfax
    Dale Fairfax
    Sounds to me like you should NOT have reversed it.
  7. falcongeorge
    falcongeorge
    from BC
    I have been thinking the same thing. I am accumulating parts for a late sixties style build, when I was hunting for my Corvair box, I specifically looked for one that hadn't been reversed so my options were open. I plan to leave it that way until the chassis is together, the body is mounted, and it is sitting on its wheels, then I can really suss it out. Plan to use split model A bones, if I can end up with the drag link almost the same length as the bones and running parallel, I will probably run it arm up.
  8. mink
    mink
    from CT
    cross steering with a vega box?
  9. pitman
    pitman
    Your mention of being setup LOW, brought to mind the pitman arm/draglink kissing the pavement issue, on certain low slung T-bucket builds. Certainly a concern if so!
