Technical Steering rod snafu
Discussion in 'The Hokey Ass Message Board' started by Josh1940, Jun 17, 2022.
  1. Josh1940
    Josh1940
    Alright, I'm in mock up stage, ignore no jam nuts and what not. When I acquired this 40 chevy pickup it had a janky straight axle with true suicide front with the steering rod out front. I'm wondering if i slice a angle off front of frame and could I put the heims on underside of steering arms? I don't want to go in front of axle, Ackerman would be jacked. Waiting on wheels to get weight of jack stands and see where she wants to sit. 20220617_152056.jpg 20220617_152007.jpg 20220617_151939.jpg
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Gonna have to see a whole lot more than that ...
    427 sleeper and dana barlow like this.
  3. goldmountain
    goldmountain
    Back up a bit and take a picture.
  4. Josh1940
    Josh1940
    It's hard to translate with junk phone pictures vs the eyeball in person. Frame is on stands, I've got about 1/8 inch between front of frame and steer rod. Is it I'll advised to heat and bend my steering arms to gain the clearance? I don't see any other way other than frame modifications or extending spring perch forward. Thank for the replies guys.
  5. HOTRODPRIMER
    HOTRODPRIMER
    That steering rod looks extra sketchy. HRP
    olscrounger and VANDENPLAS like this.
  6. AccurateMike
    AccurateMike
  7. Josh1940
    Josh1940
    I maybe use the wrong terminology, which one is sketchy, it is just mocked up and that's why I'm asking. The rod from steering box can be changed, that's what was on it. The rest is all new front end parts.
  8. goldmountain
    goldmountain
    Please take a picture of the left rotor / spindle from the other side.
  9. Josh1940
    Josh1940
    About as square away looking down it I can get. With weight off jack stands that dang rod is too close. 20220617_173133.jpg 20220617_173206.jpg
  10. HOTRODPRIMER
    HOTRODPRIMER
    What type of steering box are you using, a photo that shows how the box is mounted in relation to the steering hoop attached to the drivers side spindle. HRP
  11. junkman8888
    junkman8888
    From what I can see:
    First, if the rest of the frame looks like the front, I'd seriously consider building a new one.
    Second, you can't use hairpins with a tube axle. The axle can go up and down, but you can't have twist (suspension compliance) without bending parts that will eventually fail, like hairpins, batwings and frame mounting brackets. If you're going to use a tube axle you need to have it set up for four-links to be safe.
    You should be using grade 8 hardware on all suspension components, and if you use nylocks you need to have at least three threads showing past the end of the nut, like the front spring shackle mount that is bolted to your batwing. Best of luck with your project.
  12. goldmountain
    goldmountain
    I was asking the same question as HRP.
  13. Josh1940
    Josh1940
  14. Josh1940
    Josh1940
    I'm not a pro hotrod builder, but I know I need to get all the right hardware fasteners, like I said mocking up front. No idea on steering box but I took it apart and cleaned and regressed and tightened up slop. 20220617_181406.jpg 20220617_181222.jpg
  15. dana barlow
    dana barlow
    from Miami Fla.
    Steering arms on spindle,looks like the aftermarket things?< Many of those are designed and made=with zero*{None} Ackerman/so they say you can use them front or back:confused:<They don't work well ether way,do too wrong Ackerman in both ways /check them for Ackerman. Rod ends can go top or bottom,as long as tierod clearrs bones n frame.
    Tman likes this.
  16. 1971BB427
    1971BB427
    from Oregon
    Sounds like you're referring to the tierod, and not the steering arm? Or am I misunderstanding your statement? The kinda rusty rod coming off the steering box is the pitman arm. The gold flatbar arms are the steering arms, and of course the rod that ties the two steering arms together is the tierod.
    Edit-I missed the last picture showing the arm and proximity to the frame rail. I'd unbolt it from the spindle, and simply cut some off the end closest to the frame. Then weld a plate over the area, and smooth it of to repaint.
    Mr48chev and dana barlow like this.
  17. twenty8
    twenty8
    Good advice, but probably will be ignored just as it was in the OP's previous thread.
    https://www.jalopyjournal.com/forum/threads/setting-caster-radius-rods.1266200/#post-14508579
  18. Tie rod hitting front of frame bad, like @dana barlow said, find better steering arms. As for the tube axle and hairpins? A million T buckets can't be wrong. This is not rocket surgury
    dana barlow and 2OLD2FAST like this.
  19. Josh1940
    Josh1940
    Yes, the tierod is my biggest hangup right now with close proximity to frame.
  20. twenty8
    twenty8
    Each of the million T buckets doesn't weigh as much as a '40 Chevy full bodied pickup........:rolleyes:
    Hairpins and a tube axle may very well survive, but it certainly raises the chances of it failing, and that usually doesn't end well.
    olscrounger likes this.
  21. From what I see here we are looking at more of a fenderless rat rod/bobber abomination with the weight bias similar to a T bucket. Just trying to help the dude out.
    TA DAD and 2OLD2FAST like this.
  22. twenty8
    twenty8
    All good, it's just discussion, but it doesn't get past the fact that a tube axle with hairpins just can't physically work without placing substantial extra stresses on mounting brackets. I don't get why you would want to do that....... but that's just me.:)
    Using hairpins with an I beam axle is ok. They can work together to control roll, but make sure the mounts are up to it.
    As for T buckets, are you ***uming they have any actual usable movement in the front suspension?
    Most have 3/16th's of 5/8th's of f*#k all.
  23. Josh1940
    Josh1940
    I don't know if I need to **** or go blind now. Thanks for all the advice y'all, I'm not ignoring anything anyone says, but I'm not starting over. I will test and adapt and this truck will drive and handle how I make it. Gonna have a beer!
  24. These might help you, Ford, Jeep and others made em. Might make the tie rod dangerously low however
    dana barlow likes this.
  25. Josh1940
    Josh1940
    I'm not gonna throw this pickup on a touring track or offroad and articulate the front. I have a I beam straight axle from the early 40's on the garage floor in s**** pile. I can guarantee you you aren't going to twist or have much more "give" in that old metal, it is ridgid.
  26. Josh1940
    Josh1940
    Those probably would work tman, thanks. I got aftermarket speedway brackets that don't accept tie rod ends, but I'm not beyond changing those. Thanks for all the help. I'm learning a lot
  27. twenty8
    twenty8
    You should do a bit of research and reading on tube vs beam axles. Interesting stuff, and lots to learn.;)
    It's all been covered on the HAMB many times. A search will give you lots of good info.
  28. Josh1940
    Josh1940
    Thanks twenty8, I will check it out.
    twenty8 likes this.
  29. alchemy
    alchemy
    The tie rod is the farthest back during straight ahead, right? If it clears then, it should clear on a turn. Try it and see. Maybe you can bend the arms down a little, effectively shortening them and getting more clearance from the crossmember at the same time.
    To bend those flat steel arms (hokey junk that really shouldn't be used on a hot rod, but you did say you were going to use all the parts you already had) I'd suggest a big press brake instead of heat.
