steering setup/design
Discussion in 'The Hokey Ass Message Board' started by goinfast, Apr 25, 2010.
  1. hey guys just wondeing if this setup will work as long as use double u-joints and a support bearing. i need to navigate around a bigblock with headers and my only real route is to go under the motor mount. will this work?
  2. barnescole
    barnescole
    definitely need support bearing, but yes...should work. i'm ***uming power rack. keep angle at rack as small as possible.
  3. metal man
    metal man
    That's right , it'll work fine . Use a support bearing between the 2nd and 3rd joints and don't exceed the limits of the joints ( angle ).
  4. scottybaccus
    scottybaccus
    Modify the rack mount to rotate it rearward so that you can ditch the front joint. You will still want a support bearing just ahead of the rear joint, but you will be much happier with the results.
