Hot Rods Steering shaft Diameter
Discussion in 'The Hokey Ass Message Board' started by Admiral Tom, Mar 28, 2025.
  1. Admiral Tom
    Admiral Tom
    Can anyone tell me what the diameter is of the steering shaft on a 1936 Ford Pickup? I believe the outer tube is 1-1/2", I don't know the inner shaft. Thanks!
  2. Mr48chev
    I'm wanting to think 3/4. Some sources say that some pre 40 Ford trucks had a shaft od of 7/8 though.
    Years ago I came up with a Ford steering shaft that someone had torched the column off just above the box when removing the body from the frame and that shaft served as my spacer source when I needed to make a spacer to use with a 3/8 bolt for years.
  3. Budget36
    Budget36
    I’ve a ‘40 box in the shop, ***ume it’s the same? I’ll see what the diameter is of it a bit later
  4. warbird1
    warbird1
    The OD of that shaft is just over 3/4" at .760 diameter... that what the '40 shaft that I just put in my roadster was.
    osage orange, AVater and Budget36 like this.
  5. Admiral Tom
    Admiral Tom
    Thanks Warbird1
