Customs Steering shaft dilemma.
Discussion in 'The Hokey Ass Message Board' started by flatout51, Jan 30, 2025.
  1. flatout51
    flatout51
    I'm trying to get my steering set up on my shoebox but can't find a support bearing for the end of my column. Everything i read says my steering shaft should be .75 but mine is closer to .7625. All the shafts I have are the same too, no matter the year. Kinda going nuts over here. Anyone else run into this? Thinking about taking it to a machine shop to have it turned down but would rather find an easier solution. Also cheaper.
  2. 19Eddy30
    19Eddy30
    from VA
    Br*** or Bronze stock, others will mention other materials
    Turn / bore to your spec , ID & OD
    .750 -1.000 or so thick
    alanp561 likes this.
  3. DDDenny
    As I always ask, what type of measuring tool are you using and is it calibrated?
    .7625 is equal to 19.45 mm, the closest metric bearing available to that has a bore of 19.5 mm, that may have some clearance, need to know the outside diameter required to fit inside of your column mast jacket.
    I see one is available with an outside diameter of 1.791, there may be others.
    Twelve bucks
    Here:
    https://www.ebay.com/itm/365018517875
  4. RICH B
    RICH B
    You can use a chunk of Delrin or other plastic and "machine" it at home spinning with a drill. If you know someone with a 3D printer, it could be printed too.
    olscrounger and jimmy six like this.
  5. flatout51
    flatout51
    Digital caliper. The outside diameter needs to be 1.375 for the Shoebox coulmn. I've looked at most online supply shops and can't come up with one.
  6. flatout51
    flatout51
    Delrin is a good idea. The header is pretty close to the column where the bearing is needed i wonder what heat delrin can withstand.
  7. flatout51
    flatout51
    I have an extra bushing that goes at the top of the column. It's a bronze bushing in a rubber sleeve. I used sand paper to open it up to a nice slip fit but wasn't sure if the rubber would withstand the heat from the header. Speedway sells a length of .75 tubing with .120 wall for steering. I could cut the splined end off mine and weld it to that shaft from them. Make a plug that is press fit into but the new shaft and the old splined shaft. Then weld and drill it for a plug/ rosette weld.
  8. flatout51
    flatout51
    Well I was able to take a sanding drum on my die grinder and slowly open the bearing and lock collar up till it was a tap on press fit. I went ahead and did a spare just in case. Looks like it will work out just fine. I will split the column and add a clamp to hold the bearing too. 20250205_130944.jpg
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Rather than splitting the column and adding a clamp use this Lock***e. NOT THREAD LOCKER. Lifetime
    Kerrynzl, alanp561 and flatout51 like this.
  10. mgtstumpy
    mgtstumpy
    I added a delron bushing with inner bearing, there's circlip groove on engine side of inner shaft and a collar on inner shaft (Inside tube) to prevent any movement as well a new mast bearing at top of column. A grease ****** on underside secures bushing to tube.
    olscrounger and Speccie like this.
  11. 1971BB427
    1971BB427
    from Oregon
    I just drill and tap a hole through the column and into the bushing. Put a screw in to hold it, and it's great. I also put some grease on the shaft before sliding the bushing into the column.
