Technical Steering shaft splines
Discussion in 'The Hokey Ass Message Board' started by KenC, Aug 6, 2022.
  1. KenC
    KenC
    I'm using a OT tilt column in my 56 Dodge pickup so will be needing a steering wheel soon. What years of GM wheels will have the same spline OD and count at a 79-80 Firebird.?
    Shooting for around a 15" wheel with maybe 2" of dish. I don't have the seat and column completely installed so the 2" is a guess, flat may work but not little bitty wheels with lots of dish!
    I think 60s-80s probably, but before I hit the Upull I'd like to be sure.
    dana barlow likes this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Since your dealing with a vehicle built in 1956. Any GM wheel 1955 and up will fit shaft/splines.
  3. dalesnyder
    dalesnyder
    Sixties cadillac were an odd spline.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Fair Enough. But I’d never use a Caddy wheel on anything.
  5. KenC
    KenC
    I guess I wasn't clear. The vehicle is a 56 Dodge PU, getting a 79 Firebird column. I suspect your answer will be the same though?
    I was hoping to find a chevy pickup wheel that is close to the right diameter. Some of the 60s/70s had a look that i like, right diameter and sort of plain.
  6. willys36
    willys36
    My '53 pickup spline fit an 80s tilt column perfrctly. Just had to cut about 1/2" of Bakelite off the wheel to let the shaft penetrate adequately. Had to bondo on a sheet metal disk to adapt the wheel shape to match the column top.
    IMG_0858.JPG Pc010224.jpg PC010221.JPG PC010226.JPG PC010227.JPG P8010078.JPG P8020080.JPG P8020090.JPG
    KenC and Tman like this.
  7. KenC
    KenC
    Thanks Willys! good job and good info.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You we’re clear. 79 falls under 1955 and up.
