Technical Steering Shaft U-joints
Discussion in 'The Hokey Ass Message Board' started by Voh, Apr 22, 2024.
  1. Voh
    Voh
    I am looking for some help on steering / steering shafts. I have slight play in the steering wheel after replacing a number of components. Only thing left is the steering joints. I know of Borgeson brand. Is there anyone else i should look at or are they who I should use?
    VOH
    Tow Truck Tom likes this.
  2. Marty Strode
    Marty Strode
    Sweet mfg. Sold by Speedway Motors. Smaller and better than Borgeson, in my opinion.
  3. AccurateMike
    AccurateMike
  4. da34guy
    da34guy
    X2 Sweet joints
  5. Bandit Billy
    Bandit Billy
    Cheech Marin make those?
  6. 31Apickup
    31Apickup
    I’ve run Borgeson’s no issues, one of mine has been 30 years and no play.
    Tow Truck Tom and Voh like this.
  7. Fogger
    Fogger
    My last three builds I've used Porsche 914 steering shaft u-joints. They have pinch bolts instead of the set screws and jam nuts that some use. I don't have a part number but the 914 u-joints fit the 3/4"-GM splines.
    Speccie and Tow Truck Tom like this.
  8. pirate
    pirate
    from Alabama
    chevyfordman likes this.
  9. 42merc
    42merc
    I have used Sweets in the past. I found that they developed play after a short use.
    They are good looking & compact.
  10. Dan Timberlake
    Dan Timberlake
    "Only thing left is the steering joints."
    I'd think significant play would likely be visible if I could get up close, of have a bore scope camera deal.
    And definitely "feel"-able with a finger spanning the components, and a helper turning the wheel.
    Having the car sitting on its tires while slightly steering back and forth can provides useful resistance to help reveal loose stuff.
  11. seb fontana
    seb fontana
    from ct
  12. BamaMav
    BamaMav
    from Berry, AL
    Another vote for Borgeson. I changed out my generic joints with a pair of Borgeson, all the slack disappeared from my steering. Even the DD shaft was larger and finished to closer tolerances. Might use the old generic stuff on a lawnmower or something else slow, but for the highway, you can’t beat Borgeson. You get what you pay for.
  13. da34guy
    da34guy
    Now dats F N funee
  14. Voh
    Voh
    Thank you all for the feedback. Am I correct that a support isn’t typically required with (2) joints? I have one at the bottom of the column and one at the splined input.
    VOH
  15. milwscruffy
    milwscruffy
    Have you checked the steering box adjustment before ***uming the joints are loose ?
  16. evintho
    evintho
    gotmark73 likes this.
  17. bill gruendeman
    bill gruendeman
    If the free play is coming from the joints that should be very easy to see by the naked eye without tearing the steering apart. I would look at the box first.
  18. 38Chevy454
    38Chevy454
    Correct, a support is not requuired if both ends of the steering shaft are held in place. With 2 u-joints the shaft can't go anywhere. With 3 u-joints you need the extra support since the shaft can flop around without it.
    Voh and AccurateMike like this.
