Steering stops????? Need help and advice.
Discussion in 'The Hokey Ass Message Board' started by fiat gasser, Feb 24, 2014.
  1. fiat gasser
    fiat gasser
    I have finished up the steering in my Fiat Sedan Delivery project but as the wheels make there turn they go a little to far. I would like to come up with some type of stop to minimize the turning radius. Any help or suggestions would be appreciated.
    Thanks,
    Bob
    I'll post some pic's shortly.
  2. fiat gasser
    fiat gasser
  3. fiat gasser
    fiat gasser
  4. fiat gasser
    fiat gasser
  5. fiat gasser
    fiat gasser
    Lots of lookers but nobody has stood up to help. Really uncommon for the HAMB. Just looking for an idea, suggestion or pictures of the best way to address the problem with the steering.
  6. leadsled56
    leadsled56
    I will take the bait and make a suggestion. What about a bracket holding a bump stop rubber that can first be clamped around the axle tube and then once fine tuned welded in place? Looks like the spindle arm would make contact if turned far enough.
  7. fiat gasser
    fiat gasser
    Thanks laedsled56,
    A bump stop is a good suggestion. I will take a closer look at that.
  8. Jalopy Joker
    Jalopy Joker
    what kind of steering rack is that? for Mustang stuff there are different length rods available.
  9. butch27
    butch27
    Darn nice work. Can't wait to see it moving.
  10. fiat gasser
    fiat gasser
    It is a Appleton rack and pinion. Bought it from a guy who had it in a 41' Willy's. He replaced it with a power rack setup.
  11. fiat gasser
    fiat gasser
    Thanks Butch.
  12. 50dodge4x4
    50dodge4x4
    The easiest place to put a steering stop is at the king pin housing and the steering knuckle location, at the front of the kingpin housing on each side. It will be a trial & error process where to build up the stop with a welder and shape it with a grinder. There are little bumps (might be nuts) at about the proper location on your pictures (last one showing the inside of the front), they just look like they are too small. The stop doesn't have to be very robust (just a positive stop), you won't be forcing it when it makes contact. Gene
  13. toxic waste
    toxic waste
    from Iowa
  14. stimpy
    stimpy
    I was thinking along the lines of a triangulated gusset with a hole drilled in it and nut welded over the hole on front side of the axle tube just inside the king pin tube and use a bolt with a double nut to adjust the distance you need make it so it hits on the spindle back side
  15. gimpyshotrods
    gimpyshotrods
    Move the heim joints to the other holes on the steering arms.
  16. Zuffen
    Zuffen
    from Sydney
    Have you thought about dismantling the rack and putting a stop on the rack teeth to effectively shorten the distance the rack can move inside the box?
    I figure you could fill a few teeth (how many is up to you) on either side and this would shorten the rack travel.
  17. stan65
    stan65
    from Toledo, IL
    I know it's a lot of work, but moving the rack forward and attachment points on the steering arms forward would reduce travel, make the steering effort easier, and slow down your ratio (less twitchy)
    Just my .02
    Stan
