Hot Rods Steering stops
Discussion in 'The Hokey Ass Message Board' started by bob giles, Dec 1, 2010.
  1. bob giles
    bob giles
    Did typical straight front axles have steering stops? A RPU project I bought will turn far enough to bind the brake hoses and touch the headlight buckets.
  2. F&J
    F&J
    The ford axles have an acorn shaped nut that acts as the stop. It is the nut that holds the king pin "keeper" bolt in the axle ends.
  3. fleetside66
    fleetside66
    I was wondering the same thing. My 4" dropped axle doesn't hit anything, but I overextended my steering dampener & ruined it. I'm thinking of fabbing some sort of stops to prevent it in the future.
  4. HotRod31
    HotRod31
    Yes F&J is right, kinda looks like a mag wheel lug nut, speedway sells 'em.
    Later, Mark
  5. GARY T.
    GARY T.
    from S.W. Pa
    The ones from Speedway are Chrome and are 1 1/2" and are $19.99 for 2
    Macs has them in plain steel --they are 1 3/16" and are $2.90 each
  6. tommy
    tommy
    You can see how long the nut is that holds the kingpin retainer. The spindle hits the end of that long nut.
  7. 29 sedanman
    29 sedanman
    from Indy
    On my last car I used 1/2" fine tall chrome lug nuts for steering stops. Worked great, and cheap.
  8. VAPHEAD
    VAPHEAD
    I've seen tube axles that only use a set screw for the king pin.
    Maybe that's what he has.Then what?
  9. Blue One
    Blue One
    from Alberta
    Take out the set screw and install a stud then a long lug nut as shown.
  10. VAPHEAD
    VAPHEAD
    Blue One, I guess you have never seen what I was talking about.
    The set screw is like a #10 screw
  11. Blue One
    Blue One
    from Alberta
    Thats pretty tiny.
    I'd probably take it all apart and weld a nut to the back of the kingpin boss.
    Then install a stud in the nut and a steering stop acorn nut on that.
  12. GARY T.
    GARY T.
    from S.W. Pa
    WOW a #10 screw---don't know if I'd trust that???:eek:
  13. fab32
    fab32
    I've seen the tube axles with the set screw. I think Blue One has a reasonable solution. Other than that I'd suggest a shapped gusset that could be welded to the axle boss an then trimmed down until the right steering radius is found.
    Frank
