Steering trouble questions
Discussion in 'The Hokey Ass Message Board' started by Nocero, Feb 27, 2004.
  1. Nocero
    Nocero
    I posted last night about a minor steering problem I was having, and after sleeping on it decided I can probably lengthen my steering arms out. Anyone know if there is a formula to figure out how much a said distance will affect the ratio. The steering arms are cast into the spindles so I'd like to cut once and measure twice.
  2. yorgatron
    yorgatron
    wha??? BTTT for tech
  3. Digger_Dave
    Digger_Dave
    [ QUOTE ]
    I posted last night about a minor steering problem........
    [/ QUOTE ]
    Help us out here, what kind of problem are you having??
    [ QUOTE ]
    ...The steering arms are cast into the spindles so I'd like to cut once and measure twice.
    [/ QUOTE ]
    Cutting steering arms; and re-welding is a job for someone who is a VERY good welder; and SHOULD ONLY be done as a last resort.
    If the problem is "clearance", (steering arms running into something) they can be repositioned using heat and CAREFULL bending.
    Cutting isn't recommended, and changing arm lengths leads to all kinds of other headaches.
