Steering U Joint Questions??
Discussion in 'The Hokey Ass Message Board' started by Duke, Dec 31, 2010.
  1. Duke
    Duke
    I am setting up the steering system on my A coupe and I have run into a problem. I built my own column (58 caddy shaft in a 1.5" pipe so I could use the 58 caddy wheel), the bottom of the column is 3/4 DD. I attached a flamming river 3/4 DD joint to the column (part number FR2716DD) and this attaches to a section of 3/4 DD shaft. The problem is the joint that attaches to the steering box (part number FR2522DD) is out of phase with the joint on the column. The joints are 90 degrees out of phase. Is there another joint that should be used instead of the one I have? The steering box is Vega (5/8 - 36 spline).
    Thanks
  2. are both u-joints from flaming river? if so , they should be in phase...that's what the DD shaft is supposed to do. pictures?
  3. Duke
    Duke
    Yes, both joints are from flamming river. I will try to get a picture.
  4. Duke
    Duke
    Here it is.
  5. RidgeRunner
    RidgeRunner
    from Western MA
    Try swaping the joint on the right end for end?
    Ed
  6. HotRod31
    HotRod31
    It looks like you can turn the double d joint on the colum end.
    Later, Mark
  7. Duke
    Duke
    Tried that, same result.
  8. budd
    budd
    looks like on the right joint the flats are lined up with the joint ends and on the left they are perpendicular, i say you need one new joint.
  9. mt shasta steve
    mt shasta steve
    It is my understanding that 90 degrees out is fine. It's when you are other than 90 or straight that you have problems. My coupe is 90 degrees out like yours and no problems, so is the '41 truck. Think about it, it's not turning 5000rpm like your drive shaft.
  10. BJR
    BJR
    Maybe this is stupid, but can you heat the long DD shaft in about the middle and twist it 90 degrees to phase the joints?
  11. RDR
    RDR
    straight on or 90 degrees is fine....the joints are inline with each other...that's what is critical...
  12. Duke
    Duke
    I looked on the Borgeson web site and they have a picture of some joints out 90 degrees and they say it is wrong. The confusing thing is that flamming river does not list a different joint with 3/4DD and 5/8 36.
  13. langy
    langy
    I've seen joints like this and they seem to work fine, saying that though i prefer to see them in phase.
  14. Duke
    Duke
    Is anyone using flamming river joints in a two joint set up with the joints in phase?
  15. wingedexpress
    wingedexpress
    Just get some 3/4 round shaft and grind the double d ends opposite of each other.
  16. racemad55
    racemad55
    Your kidding aren't you?
  17. 37mj
    37mj
    :eek: :eek: wtf
  18. seb fontana
    seb fontana
    from ct
    Nothing wrong with the joints as is in the pic...As previously stated you never gonna turn them that fast to ever notice anything, even if the angles are extreme..No one will ever notice...
  19. dave lewis
    dave lewis
    from Nampa ID
    As long as the cross pins are "aligned", they are in phase....
    The pics tell the story, you are good to go !
    Dave
  20. inline 292
    inline 292
    Looks like there are two set screws 90 deg. apart on the left side joint. How about if you just loosen them two screws & rotate that joint 90 deg. on your DD shaft.
  21. micky69
    micky69
    from Ohio
    Hi, I work in the Tech/Sales Dept at Flaming River. You have 2 different series of joints after looking again. ( I posted a differnt reply earlier). You need part number FR2516DD for that column joint. I would return the FR2716 to who you purchased it from for an exchange. I believe it may be either old stock or just machined differently for some reason which is odd. Make sure it has Flaming River engraved in it too. There are china knock offs now also. If I can help call me at 800-648-8022 ext 113. Micky
  22. Ebbsspeed
    Ebbsspeed
    Nice to get some input from one of the folks at Flaming River, Kudos!
  23. Duke
    Duke
    Thanks Micky, would the FR2722DD work instead on the vega box? I like the pinch block design of the joint on the column, it looks like it could never come off.
  24. micky69
    micky69
    from Ohio
    I'd have to look it up and even see what sizes we offer it in. The pinch joints are not that popular to be honest, mostly because they are so bulky. Most people just do the standard 25 or 17 series joints. The way it is set up will work as others have mentioned, not totally correct, but not going to hurt anything either.
  25. Duke
    Duke
    Thanks Micky, I sent you a PM with some more questions.
  26. 4woody
    4woody
    I accidently did mine out of phase and in spite of what has been said, you can feel a subtle loose spot and a tight spot as you turn. Bugs me enough that I'm going to spend the time & $ to do it over, and my joints are welded on so I have to buy 2 new ones.
    Fix it right.
  27. micky69
    micky69
    from Ohio
    If they are our joints we reccommend that you dont weld them, that can also cause the loose and tight spots as it can mess up the needle bearings.
  28. 4woody
    4woody
    Nope- not yours.
    Sorry if it sounded like that. They were weld-on joints though.
  29. langy
    langy
    I would like to see thay done :D It would be a good trick :rolleyes:
  30. joee
    joee
    not maybe stupid ,it is one of the most stupid questions ever asked......please tuen in your membership as you are banned from this site. You now will only be allowed on sports car/rat rod sites...............
