Technical Steering Wheel advice needed
Discussion in 'The Hokey Ass Message Board' started by Wizard1926, Jul 26, 2023.
  1. Wizard1926
    Wizard1926
    Just about have the 26 Tudor ready for the road.....yahoo
    The steering wheel that came with it, well let's just say its***** ugly to me and really doesnt go. Its 14" and all wood. Have not done any steering wheel swaps in the past so looking for your wisdom and advice.
    What style do you think would go and adaptors? Help an old dummy out...
    Thanks
    Just Gary likes this.
  2. squirrel
    looks like it probably has a normal 3 bolt adapter under that rounded piece, below the rubber bellows. So you could use a normal old aftermarket steering wheel like a 3 spoke Superior 500 or something.
    If you take the existing wheel off, then you can see what you have to work with, eh?
  3. Wizard1926
    Wizard1926
    If you take the existing wheel off, then you can see what you have to work with, eh?[/QUOTE]
    That's my plan in the morning. Cant screw up to much....right
    Thanks
    Bill
  4. 56don
    56don
    That wheel is uglier than my*****.
    How about one of these "traditional" wheels:
    :eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
  5. Wizard1926
    Wizard1926
    LOL..... Would have to wear oven mitts in the south texas sun and heat to use that one.
    Makes me think of cheech and chong
    56don likes this.
  6. Bell wheels are pretty timeless.
    Whatever wheel you use I would have a nice leather cover made to replace those fugly rubber bellows.
    Tow Truck Tom likes this.
  7. el Scotto
    el Scotto
    from Tracy, CA
    It's got two stacks of those wheel extenders with the rubber ribbed for her pleasure covers. Yikes!
    I'd definitely be finding a new solution, not only because that wheel is oooog-leee but for safety's sake. :eek:
    If you don't have a favorite style pick an era and do some detective work on what was cool that year. Find a JC Whitney from those years and see what was hip. :cool:
  8. Oh! thats an extension!!! Still fugly. Proper dished wheel may get it in a good position w/o using it.
  9. el Scotto
    el Scotto
    from Tracy, CA
    Two extensions bolted together, then bolted to the adapter and then the steering wheel. Not just ugly, but likely dangerous... :confused:
    Way too much happening there for my taste... :eek:
    Tman likes this.
  10. jimmy six
    jimmy six
    Moon sells old style Covico’s
  11. nobby
    nobby
    to me it looks like you have a 1968 camaro style column
    on top of the column is a grant style upside down bowl
    under that is probably a 3 bolt grant adaptor.
    what you probably have is a chevy spline, which is great,
    history lesson
    in 1968 the ford mustang went from a nice deep 3 spoke wheel to a foam padded horrible style wheel
    maybe it was some kind of federal law that coinsided with the introduction of collapseable steering columns
    so prior to 67 steering wheels were generally of a deeper 'bell' than post 1968
    also worth noting is the turn signal switch changer in 68 up on gm columns
    for arguments sake look at a 67 mustang wheel and a 68
    then look at a gm offering from 66 then 69
    no one back in the day wanted to run stock steering wheels, but they do now
    or - go and have a look at the price of a stock chevy 2 steering wheel $$$$$
    you couldnt give them away i bet in 1985
    so a 64 to 67 gm wheel - the distance from the hub to the ring of the wheel is nuch deeper than post 68
    it is difficult to see when you are looking at pictures head on.
    plus
    all stock steering wheels are quite large in diameter
    find a stock corvette c2 hub
    aftermarket c2 smaller wheel
    corvette horn push
    looks similar to a nardi wheel and may have the distance you need which might be the discerning factor
  12. Wizard1926
    Wizard1926
    I agree 100 %
    I pulled the center of the wheel off. Looks like if I remove the 2nd spacer (and throw it away), a standard 3 bolt wheel will work.
    I'll measure the dish and get the proper wheel on it.
    Thanks everyone for your help and advice.
    I'll get the spacers off there
    Bill
    Mr48chev likes this.
  13. Wizard1926
    Wizard1926
    Great information! Thank you. Will give me some research to do
    Bill
  14. Wizard1926
    Wizard1926
    I will take a look. Thanks
  15. Wizard1926
    Wizard1926
    Speedway has a 15" wheel like that. Like the looks. Might just have to get it
    Bill
  16. nobby
    nobby
    the one thing that will get you is that the top part of the styeering column is in the usa called a upper column collar
    they are not all the same diameter.
    the size changes in diameter with the change of the turn signal switch
    its basically 57 chevy
    68 camaro
    85 camaro
    57 chevy its just a turn signal - hi low and hazard switch on dash
    68 camaro incorporates the hazard switch i think hi lo on floor still
    68 up the hi low is in the collar with the hazard and turn signal switch
    erm - something like that
    just worth noting if you go for a stock wheel
    Wizard1926 likes this.
  17. Wizard1926
    Wizard1926
    Thank you for the great information. If I go stock whell, I'll check, fairly sure mine in camaro.
    Bill
  18. nobby
    nobby
    look at the depth of a c2 steering wheel adaptor
    and the dish or 'bell' of the wheel
    it all kind of adds up to the 60's deep dish
    will put the wheel plane where yours is now.
    buy a c2 corvette wheel.
    IF you put a 40's style wheel on that column it will be too far forwards
    anything flat will not suit the steering column
    a c2 vette wheel will look the best.
    the aftermarket curved spoke banjo 1939 ford style made by some dude - i forget who, is the nicest wheel on the planet, and will be the correct diateter at the mounting as your column as i have one on a non tilt 68 camaro upper collar, but I swedged the tube down to 1.5'' to go into a stock column drop. plus i think i had to mill in some snap washers either side of the collar bearing, i forget now.
  19. Wizard1926
    Wizard1926
    Thank for the advice nobby !
    Bill
  20. Bandit Billy
    Bandit Billy
    You may be able to sell that wheel to a guy building a rat rod trophy. Damn.
    Wizard1926 and Jim Bouchard like this.
  21. That's so you can drive with handcuffs on..
  22. stuart in mn
    stuart in mn
    One good thing about it is that after you do the swap you can set this one on fire. :)
    Wizard1926, loudbang and Jim Bouchard like this.
  23. blue 49
    blue 49
    from Iowa
  24. Mr48chev
    Good enough, Now all you have to do is figure out how deep a dished wheel you need and what diameter you want and start looking for what YOU want.
    Then haul that wooden piece of ugly to the next swapmeet and put a price on it and the first guys who lowballs you owns it. That shows a real bad case of "It's a Model T I gotta have a wood wheel" going on.
