Technical Steering wheel help
Discussion in 'The Hokey Ass Message Board' started by Chappy444, Jan 12, 2023.
  1. Chappy444
    Chappy444
    Doing some work on my roadster project and I am trying to sort out the steering using what I have on hand.
    My question is:
    Was there a prewar steering wheel that had 36 splines by 11/16th hole?
    My research has turned up limited answers to this exact question and I was hoping you all could clear this up.
    Many thanks
    Chappy
  2. rusty valley
    rusty valley
    Generally speaking, I believe most pre war stuff is keyed.
    SPEC and hemihotrod66 like this.
  3. nickleone
    nickleone
    Double check the 11/16 measurement. Most 36 spline shaft steering wheels I have seen are 3/4 inch.
    Nick
  4. Chappy444
    Chappy444
    Thanks @nickleone
    My caliper reads 0.681 on the outside of the splines. I figured it lost 0.006 to wear and tear over the years (and caliper accuracy)... unless I am wrong about where to measure steering shafts... which is totally possible
    Not sure what the shaft is from. It's 36 spline with no keyway or indexing.
    Thanks again
  5. nickleone
    nickleone
    What steering column is in the car ? Some modern one? Picture if possible.
    Nick
  6. Paul
    Paul
    Editor
    just to clarify
    you have a later splined column
    the big end of the splined end measures 0.681"
    and you want to fit a prewar wheel to it.
    correct?
  7. Mr48chev
    37/38 Chevy had splines and a keyway. 37 Chevy sttering wheel front (2).jpg 37 Chevy steering wheel (2).jpg
    Paul likes this.
  8. Chappy444
    Chappy444
    Thanks everyone for the input.
    Again, this is a parts pile build. I am not sure what the steering shaft is out of.. I will be using a late 30s chevy box (38 maybe)
    I had an old box and column of unknown origin that I am using the shaft and tube from. The shaft has 36 splines, no keyway, and the outside diameter of the splines measures .681. With a threaded top (1/2 x 20) I was looking for a prewar wheel I could just bolt up and go...
    I have a wheel of unknown origins (I think it is a 41 jeep wheel) that had the same diameter splines but it was 40 splines not 36.
    So, I went all hot rod on it and fired up the lathe, the mill and the press. I turned down the shaft to fit the wheel, then cut a keyway in the shaft and wheel...
    Problem solved.
    20230112_183744.jpg 20230112_183708.jpg 20230112_183658.jpg 20230113_193745.jpg 20230113_193845.jpg 20230113_200615.jpg 20230113_204958.jpg 20230113_211446.jpg
    bchctybob, 19Eddy30 and 34 GAZ like this.
  9. Thats the way to do it.. If you have the resources'...
    Nice job
  10. Oldtmtech
    Oldtmtech
    I’ve got my dad’s broaches but don’t really know how to use them but I probably figure it out when the need arises. Great job
