Projects Steering Wheel Hub
Discussion in 'Traditional Hot Rods' started by 2935ford, Feb 21, 2014.
  1. 2935ford
    2935ford
    I have a stock '32 pickup box and column with the stock tapered and keyed shaft.
    I want to use my flat 17" 4 spoke sprint style steering wheel on it.
    I need a hub (3 bolt) that will space the wheel far enough away from the dash and '39 swan shifter.
    Anyone have some idea where I can find one?
    The oriignal steering wheel allows the column to fit inside the hub as the column is not flared at the end.
  2. tommy
    tommy
    Grant made one and they might be still available. I'd check with speedway before ordering.
  3. 2935ford
    2935ford
    tommy....Thanks.
    yes, I see speedway has one but it does not look deep enough.
    I need about 3 or more inches of depth.
