Steering wheel in my 50 ford
Discussion in 'Traditional Customs' started by vwdave30, Feb 23, 2015.
  1. vwdave30
    vwdave30
    So ive tried to convince myself that i like the steering wheel in my 50 and i just cant do it. It has a 51 wheel in it. I have a cherry 46-48 chrysler wheel. I tried it on a 50 column i have and it seems to fit. What yall think?
  2. I never liked the '51 wheel. Like the '49-'50 wheel better. If the Chrysler wheel has the same splines and you can get the horn, turn signal cancel, etc. to work, go for it. I always liked a '55 Ford (Customline and Fairlane) wheel.
  3. vwdave30
    vwdave30
    Here is a close up pic of the horn ****on
  4. timwhit
    timwhit
    The Chrysler wheel looks good enough but I'd just put the 50 wheel on?? If you have one.
  5. I'm with you.
    Never did like that 51 wheel. My 49 wheel is white (someone painted it) and I wouldn't consider swapping it out. But might consider it on a 51 - unless the overriding thought is keeping an "original" feel.
    Your Chrysler wheel would look good I'd say.
    Post us a pic if you swap it...
  6. vwdave30
    vwdave30
    I need to change out my steering box mine is wore out pretty bad. I have another good steering box so thats what got me to thinkin about a new wheel. Ill be sure to post some pics when i change it out.
  7. U-235
    U-235
    I have a 51.....anything over the original would be an improvement....I'll be replacing mine with a 55 Merc Deluxe.
  8. tedley
    tedley
    from canada
    Well it's all personal taste. I don't care for the 49-50 but like the 51 and the 51 dash. Not crazy about the 49-50 dash. I used a 51 wheel and dash.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I guess it's personal preference,just like the cars we drive,I really like the 51 steering wheel. HRP
  10. tedley
    tedley
    from canada
    I just found a pic. I got rid of the horn ring which was broken anyway. Used j-b weld to fill where it needed. 003.JPG
    Maverick Daddy likes this.
  11. vwdave30
    vwdave30
    If my wheel looked like yours i would keep it but my wheel is all crusty just like the rest of my interior. I need at least one thing in my car that aint cracked and broke lol
  12. tedley
    tedley
    from canada
    My wheel was junk to so i fixed it as an experiment. Turned out so nice i used it. The plastic on mine was so cracked you could rock the plastic back and forth in spots. Don't throw it away...use it. I'm on a budget to.
  13. atomickustom
    atomickustom
    Change it. I don't like the '51 wheel and the Chrysler wheel is a beauty.
  14. vwdave30
    vwdave30
    Dont worry i wont throw the 51 wheel away imma hoarder lol i did try to fix a 49 wheel i got but i figured out i am good at makin a mess and not so good at restoring a steering wheel
  15. tedley
    tedley
    from canada
    Just v out the cracks, fill with j-b weld or equivalent, sand the filler the next day, add more if you need to. .Takes time but not difficult. Start sanding with 220, finish with 320, spray some filler primer, sand primer with 400, sealer and paint. Should take about a week lol. But you will be surprised how it turns out.
  16. dan c
    dan c
    i've done that, too, only i used epoxy paint. worked great!
  17. hbwoody
    hbwoody
  18. billsat
    billsat
    Ford peed on their own shoes when they came up with the '51 steering wheel. I'd go with the Chrysler wheel in a heart beat.
  19. Gary Addcox
    Gary Addcox
    In my younger years, the "fluid drive" would have aptly applied (hiccup).
  20. Gary Addcox
    Gary Addcox
    I really like the Chrysler wheel. I want a Ford Victoria steering wheel, but don't have '850 bucks to spend on it. Next time I hit the lotto, I will get one. My '46 wheel in my '32 Highboy was repaired and looks fine. You can do it.
  21. Gary Addcox
    Gary Addcox
    This '51 wheel looks very good with its dash. Very neat.
  22. vwdave30
    vwdave30
    Is your wheel a meteor wheel?
  23. tedley
    tedley
    from canada
    Yes it is but the only difference is the horn applique with the star.
  24. vwdave30
    vwdave30
    Got new steering box and wheel in it
    dlandberg likes this.
