Steering wheel interchange? Spline charts??
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Dec 16, 2003.
  1. Roothawg
    Roothawg
    Just doing a little surfing after KustomD posted the question about the steering wheel (Caddy) not matching up sline wise on his later column.
    Is there any reference on the web for such an interchange?
    I know Mullins, Flaming River etc. do have one but it is for the coupling end.
    Just curious. That would be of great interest to a lot of people. Maybe I'll call Grant?
  2. Unkl Ian
    Unkl Ian
    Good question.
    I know prewar Fords use a large taper and keyway,and won't directly fit anything else.
    They switched to splines after the war,not sure when.
    Are all the latemodels the same now?
  3. Kustm52
    Kustm52
    I think most of the GM stuff from the '40's through the sixties will interchange...even later than that. I had a '49 truck that had a chevette wheel on the stock column when I bought it...
    Brian
  4. Roothawg
    Roothawg
    Brian,Did you see the kustomD post?
  5. Phil1934
    Phil1934
    Take a look at a Grant book and see if the two you are looking at take the same adapter. I think each of the major manufacturers held their same splines from post WWII until they went metric in late '80's.
  6. Nads
    Nads
    from Hypocrisy
    Don't you guys know it's possible to fit damn near anything to anything else?
    Interchanges, indeed!!!!!
  7. Roothawg
    Roothawg
    Here is the reply from Grant.
    Well, I guess the long and short answer is no. There is no
    interchangeability chart.
    About the only thing that might pass for one is our application listing,
    but it won't be 100% correct as our hubs have a little more universality
    in them than many of the OEM wheels. We do not make a kit for the 1957
    Caddy, sorry. Don't know of anyone who does either; the shaft was
    indeed different and we just don't have it available.
    Sorry.
    Joey Ferrari
    Grant Products International, Inc.
    Director Technical Sales
    (800) 952-6947 ext. 314
    (818) 247-2910 ext. 314
    FAX (818) 241-4683
