Hot Rods Steering wheel issue
Discussion in 'The Hokey Ass Message Board' started by badgascoupe, Jul 2, 2023.
  1. badgascoupe
    badgascoupe
    Found this cool steering wheel .Hoping i can use in 39 Plymouth pu . Problem is someone destroyed the threaded top and ended up cutting the shaft below the hub. And no damage to the wheel itself.Any ideas how to approach this?
  2. HOTRODPRIMER
    HOTRODPRIMER
  3. TCTND
    TCTND
    Push out the stub with a steering wheel puller?
  4. Not sure how I did it but here's the photos
    badgascoupe likes this.
  5. gene-koning
    gene-koning
    Carefully cut the top of the shaft off flush with the wheel. it sure looks like that wheel is threaded onto the shaft. If after being ground flat, the shaft won't press out of the wheel, you will probably need to cut or drill the center out. The Plymouth column you have should have the wheel slide onto the smooth shaft with a key in it, and had a nut on top to lock it in place At the worst, you may have to weld what ever center piece you will need to install on your Plymouth column.
  6. 302GMC
    302GMC
    from Idaho
    That's a '53 Buick Special wheel. Take the cap off, remove horn ring. The holes for your puller are in the hub.
    It'll take a splined stub from a Buick or Cad welded to your shaft to make it work.
    vtx1800, badgascoupe and Budget36 like this.
  7. RMR&C
    RMR&C
    from NW Montana
    That shaft is mushroomed on the end from someone pounding on it. A puller won't work until you cut off the end and maybe even counter bore it down into the hub a bit
    Mr48chev and badgascoupe like this.
  8. badgascoupe
    badgascoupe
    The tips paid off it looks good!
    RMR&C and RMONTY like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What’s with the postage stamp pic? Show it off man! :) CFB619FD-BF48-47A4-BB29-0E342CFCB422.png
    vtx1800 and badgascoupe like this.
  10. badgascoupe
    badgascoupe
    Thanks all,the tips payed off,I think it looks pretty cool.
  11. Here's mine, still attached to the donor car. I'm putting it in a 1955 Buick. PXL_20230508_205548309.jpg
  12. Mr48chev
    Those are great looking wheels that don't get a lot of attention.
    Not the first wheel that I have seen that someone beat the **** out of the end of the shaft so bad that you couldn't take it off the right and simple way. Usually done by some guy who was told "just take a hammer and hit the end of the shaft and it will pop right off but wasn't told that you had to have your knees pressed tight and hard against the back side of the wheel and you had to hit the shaft square and flat.
    badgascoupe and bobbytnm like this.
