Technical Steering wheel nut missing
Discussion in 'The Hokey Ass Message Board' started by Babyboomerboy, Apr 30, 2024.
  1. Babyboomerboy
    Babyboomerboy
    I bought a steering wheel for my 1950 Ford. When I went to take off the old steering wheel I found that the nut that holds the wheel on was missing. Does anyone know what size the nut is or does anyone have a spare they would sell? Thank you
  2. Budget36
    Budget36
    I was going to do a SA comment, heck, I will anyways;)
    Sit in the truck behind the wheel.
    Look into the rear view mirror.
    You found it!
    Okay, sorry, but had to;)
  3. jimmy six
    jimmy six
    Go to your stash of fine nuts…or Take a yard stick and estimate the diameter and go to Lowe’s, Home Depot, Ace and find one… they are not “special”. They are a USS nut.
    Budget36 likes this.
  4. AVater
    AVater
    Mac’s/Eklers? Dennis Carpenter? Local Hardware store that sells loose nuts/bolts? Think it’s 5/8 fine thread but someone else will be more certain.
  5. Jeff34
    Jeff34
    They are thinner that a regular nut. You may want to use a jam nut since they are thinner.
    scotty t, jimmy six, finn and 4 others like this.
  6. pprather
    pprather
  7. alanp561
    alanp561
    Broadway Lumber, 1304 S. Broadway, Pittsburg, KS. You're welcome.
    pprather likes this.
  8. MCjim
    MCjim
    from soCal
  9. Bandit Billy
    Bandit Billy
    Or do what I did and slice a castle nut in half and sand/polish down the edges.
    Algoma56 likes this.
  10. lostone
    lostone
    from kansas
    If it's 5/8" fine thread then it wouldn't/shouldn't be hard to find a jam nut.
    Our local supply store carries jam nuts in all sizes but the good thing is being 5/8" fine thread it should be easy to find at a part store as in there are millions of 5/8" heim joints as its one of the most popular sizes and they are all fine thread and use jam nuts to lock them down. So if you have or know someone with some Heim joints chances are they have some jam nuts laying around too...
  11. Babyboomerboy
    Babyboomerboy
    Thank you all for the input. I got a jam nut and it fits like it should. That's one more thing out of the way. Thanks again
  12. DDDenny
    Glad it was a simple fix, could have been a real bad day for you if that steering wheel had popped off while driving, oh yeah, don't bother buying a lottery ticket as you have used up your once in a lifetime "lucky guy token"!
  13. nochop
    nochop
    from norcal
    I used a thin nylock
  14. ramblin dan
    ramblin dan
    Whenever I can't get a larger NF nut I usually head to the nearest factory supply store.
