Hot Rods Steering wheel restoration
Discussion in 'The Hokey Ass Message Board' started by Blown Gasket, Feb 14, 2024.
  1. Blown Gasket
    Blown Gasket
    So I'm going to attempt to restore the steering wheel on my 57 Chevy. It's the first time I've tried anything like this.... I understand what to do and how to do it, but I have seen different recommendations for which product to use to fill the cracks? So... what's everyone's favorite crack filler? Epoxy? Bondo? Something else?
    Tow Truck Tom likes this.
  2. 36and63
    36and63
    from Wisconsin
  3. manyolcars
    manyolcars
    What do they use to restore a clear plastic steering wheel?
  4. safetythird
    safetythird
    A wad of cash that could choke a horse.
    They recast them, from my understanding.
    jvo, lostn51, Fitty Toomuch and 5 others like this.
  5. Second the PC7 epoxy. JB Weld works great for thin cracks, it will settle down in a thinner crack or break better
    Tow Truck Tom and Squablow like this.
  6. Dreddybear
    Dreddybear
    To the original poster- I agree with the pc7. I used jb weld once it worked okay. But Pc7 worked really well. This is for painted wheels.
    This. I watched one being done. They used the pc7 to fix all cracks, Smoothed the wheel, made a mold with silicone (I think). Then busted the wheel apart down to metal. Cleaned it up and chromed it, then recast with acrylic (I think under vacuum) … that’s the oversimplified version. Each step look easy to screw up. Pricey!
  7. Bugguts
    Bugguts
    There’s a guy on Fakebook by the name “ The steering wheel guy”. It’s worth a look.
    He usees carbon fiber and resin and does amazing work. I’m going to use his technique on my 40 Ford wheel. Every time I have used the other products mentioned above, the cracks have reappeared.
    TagMan likes this.
  8. X38
    X38
    A simple search here would reveal MULTIPLE threads on this subject.
  9. continentaljohn
    continentaljohn
    I’m doing a wheel right now and like to use West Systems. It’s a wicked strong waterproof epoxy that we use to building wood mahogany boats with. It will stick to anything and hard but flexible. It also can be thickened by adding silica and comes in some different colors for color matching .
  10. bobss396
    bobss396
    I went PC7 on mine and it worked for a while. It was in BAD shape and with manual steering, some of the cracks are back.
  11. proartguy
    proartguy
    from Sparks, NV
    Did the steering wheel in my ‘51 Plymouth with PC7 and eventually it started to get cracks again.
  12. Los_Control
    Los_Control
    from TX
    I plan to use pc-7 when I do my wheel ... mainly because I'm a cheap B@stard.
    I like that it comes in a quart can at a reasonable price, and easy to work with.
    Question to those that have tried it and said it started to get cracks again.
    Is it the PC7 that cracked, or is it more cracks appearing from the original 70+ year old wheel?
    Either way I feel my wheel will never be restored. It has too many tiny little ribs in it that would take a lifetime to recreate .... I will get it as close as I can, then want to add some sort of leather cover on it.
  13. oldolds
    oldolds
    The cracks happen because of expansion and contraction of the metal. When the plastic is fresh it has some flexibility and is one piece. Once it cracks it will continue to crack at the same place because it is in pieces.
    Tow Truck Tom and Los_Control like this.
  14. Phillips
    Phillips
    Hi John which product are you using of theirs? Thanks!
  15. A Boner
    A Boner
    JB WELD.
    Actually drill a bunch of small holes into the sides of the V’d out cracks, to provide extra tooth for the JB WELD to grab on to.
    Sometimes use masking tape to keep the JBW in place ‘till it sets up.
    57Fury440 likes this.
  16. K13
    K13
    Without recasting the entire wheel there is always the chance (and a pretty good one at that)that it will continue to crack. The old material is brittle, hence the original cracks, and fixing existing cracks does nothing to change that fact.
  17. BJR
    BJR
    I have used PC7 and we use it at work on all the wheels we restore. Never had one re-crack. I think it's all in the prep, and maybe the condition of the wheel being restored.
  18. The old "cracks" will be contaminated with natural skin oils and sweat from the driver's hands laid in there over many years. Flossing those cracks with solvent and files/abrasives, etc. down to a fresh, uncontaminated surface is typically required for a good bond. Shortcuts make for short fixes.
    Tow Truck Tom and BJR like this.
  19. BJR
    BJR
    We grind out all the cracks no matter how small. After the grinding the wheel looks worse that before we started on it. But we have clean plastic to stick the PC7 to.
  20. Los_Control
    Los_Control
    from TX
    I kinda get the feeling that many have used PC7 and are satisfied with it .... as long as surface is prepped properly and applied as directed ..... However, if the wheel you are starting with is a total pig, PC7 wont do miracles .... the old worn & tired wheel will continue to crack.
    I just feel like it is a very doable project for someone to take on. I will use my dremel tool and grind the shape back into my wheel until satisfied and then sand & prep for paint .... see how long it last.
  21. Zax
    Zax
    Be careful with the epoxy if you haven't used it before. Some people are allergic to it. My wife found out the hard way. I would use it in a well ventilated area and try not to get any on your skin.
  22. Squablow
    Squablow
    I used PC7 on the '40 Mercury wheel for my T roadster and by the time I had all of the cracks ground down to steel and V'd out, I think I lost like 1/4 of the original plastic. But it turned out well and has held up nicely so far.
    I find I like to over-fill the gaps I've made, let it set up for a day, and then carve it down closer to shape with a razor blade while it's still just slightly soft. After another day of cure time, I can usually sand it with sandpaper without the paper plugging up, and having cut it down closer the day before saves a lot of sanding.
    If I have little divots or small spots that need to be filled once the PC7 is cured and sanded, I've used JB weld over the top, it flows out real nice and is easier to work with for very small amounts, but I wouldn't do the whole wheel with it.
    It may eventually develop new cracks, but even a freshly recast wheel will crack eventually. Nothing lasts forever, and all roads lead to the junkyard in the end.
    nochop, A Boner, 36and63 and 2 others like this.
  23. kls50
    kls50
    I am currently repairing two 1949-50 Ford Crestliner steering wheels. I bought one in 2014-15 and repaired it with some two-part epoxy putty I bought from Amazon. It held up good and was easy to work with but developed some hairline cracks after hanging in my garage for almost ten years (not to mention the squirrels in my garage took a bite or two out of it.) J.B. weld did not work very well because it would sink into the crack and would require me to fill it in again. Either way it takes a lot of time to hand sand the contours. I do it a little at a time in my living room while watching T.V. The end result is well worth the effort.
  24. continentaljohn
    continentaljohn
    To glue ,bond,fill large cracks or voids I used the 105-205 as we have 55 gallon drums of it at work and just used a ounce or two when we had left overs when building the boat.
    I used the west system G/flex epoxy for small cracks and voids at home. I haven’t had it crack yet on a repair and only use that on my projects.
    The 105 system we use at work and we use a few gallons a week or better have zero issues cracking or shrinking when application is under .200. This is a boat so it’s in the heat cold and in the elements plus sitting in the water.
  25. 38bill
    38bill
    from Minnesota
    The steering wheels I have repaired have always cracked during our Minnesota winters. A milder climate or a heated garage would probably help keep them looking good longer.
  26. Phillips
    Phillips
    cool thanks! Hope it’s available in smaller quan***ies!
    continentaljohn likes this.
  27. proartguy
    proartguy
    from Sparks, NV
    The MoPar wheel I did was a hard rubber type of material. I am not sure what other manufacturers used, but I would imagine that PC7 would work better on a plastic type of wheel. I did v out the cracks, the PC7 was great to work with and it turned out very well after painting it. The next time I might consider using the additive used in paint for flexible bumpers.
    Squablow likes this.
  28. Unkl Ian
    Unkl Ian
    The original "plastic" cracks over time, as it shrinks and breaks down.
    Repairing the cracks, doesn't stop the degradation of the original material.
    PC7 is good, but in my experience, takes 2 or 3 days to reach full hardness.
