1952-59 Ford steering wheel restoration
Discussion in 'Off Topic Hot Rods & Customs' started by 56FORD390, Nov 1, 2015.
  1. 56FORD390
    56FORD390
    I have a wheel for my 56 that has cracks and has been painted. Is there a post or a link that would provide instructions on how to make it like new, or close to new.
  2. mikhett
    mikhett
    from jackson nj
    Vee out the cracks with a dremel tool.Use epoxy in the cracks slightly overfilling.sand them down.Paint.I did mine last year .I primed with polyester primer.Havent painted it yet.
  3. 52ragtop
    52ragtop
    from Nebraska
  4. JeffB2
    JeffB2
    from Phoenix,AZ
  5. bobss396
    bobss396
    I did the HRP fix on mine. PC-7 epoxy. I opened the cracks with a triangle file, cleaned out all the dust, hit it with some lacquer thinner to really get it clean first. The epoxy is messy and apply it sparingly... or be prepared for a ton of grinding & sanding. Sanded, primed... sanded some more. Filled minor voids with spot putty, more sand and primer until I was happy. Topped it off with a few coats of Duplicolor. I'll take some pix once I attach it with the horn ring.
    HOTRODPRIMER likes this.
  6. HOTRODPRIMER
    HOTRODPRIMER
  7. streetdreams
    streetdreams
    Did one with JB weld, using a toothpick to sparingly work it into the cracks. Sanded, primed and then basecoat/clear. holding up well.
  8. leadsledjim
    leadsledjim
    from Iowa
    I also did a Steering Wheel with JB Weld. Worked Well!
  9. Rui
    Rui
    Great tutorials, thanks.
    BTW, how is the steering wheel removed?
  10. leadsledjim
    leadsledjim
    from Iowa
    Disconnect Battery, Push Down Horn Ring & Turn, Remove Nut, Install
    Steering wheel Puller & Remove Steering Wheel. Hope this Helps!
  11. Rui
    Rui
    Sure does leadsled. It was the push down horn ring and turn that I was missing. CCW?
    Thanks.
