1952-59 Ford steering
Discussion in 'Off Topic Hot Rods & Customs' started by bulletproof1, Jul 3, 2009.
  1. bulletproof1
    bulletproof1
    from tulsa okla
    like everything on our cars the steering is a beast within its self.not much in the aftermarket for bolt on power steering.i installed the cavalier power rack .it steers great but i lost some turning radius ,has anyone else run into this prob?
  2. Paul2748
    Paul2748
    I have heard that it is a problem with the rack conversion. A number of guys have said they would never have done it if they knew about it.
  3. Madpete
    Madpete
    Hello ! My orginal steering box is in very bad condition. Now I have to consider what kind of steering system works best. I have sb chevy with headers and TH2004R.
    From 1957 Ford forum I found a link to this company http://abspowerbrake.com. They do a power steering kit for 49-72 Fords.
    Has anyone used their product ?
  4. 1hot1954
    1hot1954
    from Reno, NV
  5. missysdad1
    missysdad1
    Rick Wurth of WurthItDesigns is an old friend of mine, and very reputable. You can do business with him with confidence.
    Eric
  6. genosslk
    genosslk
    Hey... Give Jim at Jamco Suspensions a call too.
  7. rustyfords
    rustyfords
    from Conroe, TX
    Personally....I'd be content with just an aftermarket non-power box that didn't require a ton of modifications.
  8. genosslk
    genosslk
    Jamco supplies a volvo conversion kit that is supposed to work very well. When my box is total **** I will look into this conversion. Any one else here know of this kit?
  9. Madpete
    Madpete
    Thanks for these. I will report and take pictures when I got something in my hands.
    Pete
  10. Mark T
    Mark T
    Check out the power steering box from a '99-'04 Jeep Grand Cherokee, its dimensions are very similar to the stock '55-'56 box. Its not a bolt-in but with a little fab work it should work well. Search "GM powering steering 1956 Fairlane" on the main board for more info and pics.
  11. rudedude51
    rudedude51
    hey guys, i met this guy at pomona swap meet here in california. Quality Steering Parts Remanufactering heres the phone number 760-752-1766. He tells me that he can rebuild any manuel steering box even if the sector gear and the worm gear are bad
  12. Hey all, I fitted a power steer box from a late '70s / early 80s falcon into my wifes ranchwagon ( pics in album) her car is rhd but in theory a mustang from 67ish to 72 ish should be pretty much the lhd equivalent? worth checking?
  13. rustyfords
    rustyfords
    from Conroe, TX
  14. Chevydeuce
    Chevydeuce
    "genosslk
    Jamco supplies a volvo conversion kit that is supposed to work very well. When my box is total **** I will look into this conversion. Any one else here know of this kit?"
    Saw someone advertise Jamco Components with this Volvo gear here at tha HAMB not long ago but couldn´t find it on the Jamco website.
    Anybody there wo knows more about that?
  15. missysdad1
    missysdad1
    Not sure, but I think that's a Fatman Fabrications item. Good luck! Let us know how it works out, okay?
  16. Chevydeuce
    Chevydeuce
  17. Chevydeuce
    Chevydeuce
    Answer of Fatman about the Volvo Steering
    "That setup will not work in any vehicle other than the ’49-’51 Ford."
  18. tnrotter
    tnrotter
    from Tennessee
    bulletproof1, Got pics of the mounting brackets for the Cavalier rack? What year is it? Any other rack suggestions? tnrotter
  19. Mark T
    Mark T
    Check out Ebay item number 150391615706, It looks like these guys are making a mounting plate to bolt the Jeep Grand Cherokee box in '52-'56 Fords.
  20. Retro Jim
    Retro Jim
    Has anyone found a way to change the manual steering box on a 55 Ford ? Mine is ****py and hard to steer . When I adjust to get the play out of the steering , when I turn all the way left or right is gets stuck . Any help or suggestions will help . I do have a complete 57 Fairlane steering box and column .
    Is there anyone that has used a rack on their 55 ? What did you use and how bad were the modifications ?
    RetroJim
  21. JeffB2
    JeffB2
    from Phoenix,AZ
  22. Mark T
    Mark T
    I check with the Ebay seller (Item number above) and he will not sell the mounting plate without the power steering box. Looks like it should be easy enough to make.
