Stepping down fuel line size
Discussion in 'The Hokey Ass Message Board' started by ThisIsMe, Jul 25, 2010.
  1. ThisIsMe
    ThisIsMe
    from Austin
    My mechanical fuel pump to my carb both accept 5/16 line while most fuel filters and gas tanks use 3/8 line.
    Would it be a problem to run 3/8 line from the tank to the fuel filter, then from the fuel filter run a 3/8 flexible hose to the fuel pump and from the fuel pump to the carb keep the 5/16?
    I have a '60 Ford F100 with a straight 6 in it.
  2. You are not trying to feed a couple 500-cube engines.
    That's more than enough to feed a six.
  3. draggin'GTO
    draggin'GTO
    Most V8 cars built during that same time period used 5/16" line all the way from the tank.
    You'll be fine.
