Hot Rods Stewart Warner 8k Tach Pin Designation " stumped"
Discussion in 'The Hokey Ass Message Board' started by Nosebleeder, Oct 22, 2020.
  1. Nosebleeder
    Nosebleeder
    IMG_3753.JPG IMG_3754.JPG Any wire designation idea's on this old SW Tach..? I spoke to SW directly but too old to verify.. Also spoke to an old fella that's fixed them for 50 years and no luck there either...Insulators on a couple of pins... as far as I know it doesn't need an external control box.. Part # I believe is 960BF but it's super faded... any thoughts would be welcome.. thanks folks... d
    kadillackid likes this.
  2. Bob Lowry
    Bob Lowry
    If no sender needed, one has to be to the distributor side of the coil, and the other most likely would be the power or hot, source. Here are a couple of pictures from similar post from Feb, 2020...the 960 series was no longer listed by 1968.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    no sender required, the isolated copper colored stud goes to the - side of the coil, the isolated silver colored stud goes to ign power (12v) with the key on. ground one of the other "mounting studs"
  4. pprather
    pprather
    That photo is my tach. Moriarty and I agree on the wiring schematic.
    Phil
    kidcampbell71 and Moriarity like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    here is a 960 tach running on my distributor machinre
  6. Nosebleeder
    Nosebleeder
    Bob .... Terrific man.. thank-you so much .... Dave
  7. Nosebleeder
    Nosebleeder
    Now that's slick.... seen it done with my Dodge distributor, not near as nice a machine as that Sun but you can really dial your curve... awesome thanks much! d
  8. Nosebleeder
    Nosebleeder
    Thanks Phil... d
  9. Nosebleeder
    Nosebleeder
    10-4 tx dR
  10. Nosebleeder
    Nosebleeder
  11. Nosebleeder
    Nosebleeder
    Well I grew a pair today hooked the old tach up to my Dart .... gritted my teeth and touched the power post to 12 volts and it came to life... whooo I didn't buy a dud after all.... lol... win... ! Thanks again to the folks that took a minute reply... good job...much appreciated...
