Technical STEWART WARNER GAUGES
Discussion in 'The Hokey Ass Message Board' started by oldskool., Aug 20, 2020.
  1. oldskool.
    oldskool.
    from florida
    I am looking to install your typical in dash set of 3 gauges. I want 2" lighted gauges from the sixties to be period correct. Are there gauges to stay away from ( specific series **x-123) ? When did they stop making them in the USA?
  2. DDDenny
    I bought this new set of S-W winged gauges and tach for my roadster about twenty years ago (still unused) never noticed the box said they were made in Mexico, didn’t really bother me much because that was becoming commonplace.
    I started to be concerned after reading numerous complaints here about their bad reliabilty.
    They sure are pretty though!
  3. Ryan
    Ryan
    ADMINISTRATOR
    A pretty safe rule to live by: any gauge made before 1970 is better made that any gauge made after 1970. And... while you might sacrifice accuracy, the older a gauge is, the better made they seem to be.
  4. jim snow
    jim snow
    I have a full set of Stewart Warner gauges in my coupe. I did purchase them over 10 years ago and have never had a problem with them.jmho. Snowman
    Just Gary likes this.
  5. Automotive Stud
    Automotive Stud
    Sounds like you want the Deluxe series gauges. They went from the all white pointer to the needle with the black tail in the late 1970's, so to be really correct you'll want to stick with the all white needle. If you want mechanical gauges the oil gauges are usually still in working order, the temp gauges you'll have to make sure the bourdon tube isn't cut off the back, and even then I'd put a cigarette lighter under the bulb before buying to make sure it works.
    jim snow likes this.
  6. oldskool.
    oldskool.
    from florida
    To Denny,Ryan and Stud. yes that seems to be what I am hearing. And to Showman lets hope yours keep on working. Anyone else that has either good or bad experiences please chime in.
  7. el Scotto
    el Scotto
    from Tracy, CA
    You can also send out vintage gauges for repair or conversion. I've been collecting what I want visually and will have the duds restored operationally.
    What kind of gauges a car has says a lot about the car itself. I've seen some otherwise nice cars give off a sour vibe just because they're rocking an ugly set of instruments...
  8. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    There are 2 types of early gauges you need to be aware of. Back-lit and side-lit. If it DOESN'T have a hole for the bulb socket on the back, p*** on it. It's not that side lit are worse performance-wise, the external bulb makes them dim and prone to contamination (**** on the inside of the face).
  9. alchemy
    alchemy
    Eliminating side-lit from your choices will put the date to the 70's or so. I don't know the exact date, but I do know the winged and big-logo versions only had a side light.
  10. fortynut
    fortynut
    Trouble is that if you share what you know about the 'good stuff ', it's like telling the world about where you found that handful of gold nuggets. Pretty soon whatever elbow room you had turns into a shoving match and you're the one gets bounced. Anyway, my take has always been buy the best you can get. Gauges are the only indicator of what is happening to the ***orted systems that create the 'auto' part of your mobile traveling machine. I prefer big to small. I like the older stuff because it was what I wanted back when I was younger and couldn't afford it. Now that I can, no matter how shrill the whiz or loud the bang, it's quality that gets my attention. Plus, a very old and wise Armenian wrote in a book of his that I read, "Go First Cl*** and Don't Spare the Postage." That means in choosing anything try to get the Deluxe Version. Not good. Not better. Anyway, I like the mechanical gauges simply based on the idea that if you ran a magneto and the battery went sour they'd still be working. And, yeah, they offer a plastic/nylon/whatever it is line for those who don't like the vibrations transferred by copper lines to the oil pressure gauge. Hell I like noise. I think like John Cage taught, that it's music. I don't even want a radio because most of what I hear is beyond, or below my taste anyway. And, it's hard to concentrate on the road listening to Opera or Bach on a pipe organ, so forget it. I've been collecting stuff and have a question for those who know more than I do, which is probably a pretty big percentage, but that doesn't worry me. I want a Police Speedometer and see they have different ratios. What is the deal there. Can someone cogently describe what I need? And, a speedometer that reads past 120 mph? Are you kidding? I'm never going to drive all that many miles in Texas, at night, or Nevada. And, to my way of thinking the bigger the number, how accurate is it? Yeah, I've had a SW checked by a Buddy who was a Highway Patrol Officer and, you guessed it. His radar was way off. Ha ha.
  11. jim snow
    jim snow
    Mine must be the later ones as,they have black tails. Snowman
  12. RatPwrd
    RatPwrd
    Does anyone have suggestions on a good place to send vintage gauges to be tested, and repaired. I have a older set of Stewart Warners, have no idea of their working or accuracy condition?? Would like to send out and get checked to make sure I dont have to get replacements?
  13. 41rodderz
    41rodderz
    from Oregon
    I will have to research the name but there is a guy in Vancouver Washington that gauge voodoo .
  14. the Grey Ghost is the man in Washington state.
    continentaljohn likes this.
  15. Fogger
    Fogger
    All my cars have early SW mechanical gauges. I usually find them at swap meets and if they don't function I've sent them to MoMa Auto Instrument Repair in Albuquerque, NM. But it's been about 8 years since I've sent them gauges. They were in North Hollywood when I was a kid and I've stayed with them because of the quality of their work.
    1321 2nd Street N.W. 87102, 505-766-6661
    RatPwrd and kidcampbell71 like this.
  16. e1956v
    e1956v
    Alliance Vendor
    If your looking fore a Police special speedometer you want to look for a 1:1 ratio or 1000 cable revolutions per mile. Some of the motorcycle units were 2:1 which means you would need a .500 gear ratio adapter to make it work on a automotive application.
    If in proper working condition they can be accurate throughout the mph scale but I tend to worry about accuracy from 20 mph to 75 mph when calibrating on the test bench because of school zones to most state highway speed limits, if I have to sacrifice the upper speeds a little bit so be it. That being said once in the car it needs to be calibrated to a measured mile to be truly accurate, 1000 cable revolutions per mile (odometer reading of 10/10's) is 60 mph. That's done with the speedometer driven gear on the transmission or a gear ratio adapter.
    bchctybob and continentaljohn like this.
  17. fortynut
    fortynut
    Thank you e1956v. From now on, when I see them for sale, I will know what to look for. Stewart Warner has always been the only choice to make when it comes to gauges for a Hot Rod.
