Stewart Warner Speedometer
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 13, 2012.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Anyone ever have a problem with the electric Stewart Warner speedometers?
    The speedometer in the sedan works fine but it's driving me crazy,,it has an annoying click at each and every tenth of a mile. HRP
  2. A Boner
    A Boner
    Mine doesn't click, but it doesn't work fine!
  3. dirt t
    dirt t
    I had electronic wings gauges and my speedo did not click.
  4. Tony
    Tony
    Had the electric wings gauges in my old 32. No problem with the speedo, but the tach was ALL over the place..I had heard there were problems with that line..I think i read it on here a while back.
    Tony
  5. HOTRODPRIMER
    HOTRODPRIMER
    Thanks Tony,,I'll try and do a search. HRP
  6. Deuce Roadster
    Deuce Roadster
    Go ahead and JUNK that electric mess and install a cable driven SW.
    I have the speedometer cable number you will need and I will help you calibrate the speedometer to be CORRECT :)
    Try to get a older one off eBay ... the newer ones are not as well built.
    PONTNAK123 and pecker head like this.
  7. iddragracer
    iddragracer
    We are fighting the same problem in the sedan #2 works most of the time.
  8. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    New SW guages are hencho en mexico garbage, be gratefull it works at all. I had a SW wings tach take out a unilite. Called them, they sent me a new tach, but wouldnt help out on the unilite module. Bought a new module, put in the new tach..... blip, another module gone. Called SW, they had me run an ohm meter across different things on the tach. Admitted they had a "batch of bad ones" and that the 2 I got were in that bad batch,said they wouldnt help out on the module AGAIN. Offered to send me a new tach, I told them to keep their garbage.
    If it isn't old USA made SW, use it as a paper weight,,,,, might not even work well for that :mad:
  9. 3030
    3030
    Both my speedo and tach jump all over, only work when the key is off. Mexican junk!
  10. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Id run one of those goofy Dolfin gauges before I would run a new SW ANYTHING.
  11. HRP, I'm with Deuce Roadster on the old cable SW speedo. Can you see the one in my avatar? Exact same deal though mine reads to 120 MPH.
    Must be 30 years old or more, found in a old box of parts. A few drops of 3-in-1 oil, and a new Lokar cut-to-length cable and that baby is sweet as key lime pie, TR
  12. 39 Ford
    39 Ford
    Thank Bill Clinton and NAFTA.
  13. 56don
    56don
    Plus George Bush number one. Ross Perot told them both what would happen with NAFTA.
  14. A Boner
    A Boner
    How to take a fine company and run it into the f'ing ground. How do those head jerks sleep at night?
  15. kyvetteman
    kyvetteman
    Sadly, we count sheep, they count the money they made selling us out...
  16. my32rod
    my32rod
    Mine started acting up while at the good guys in Charlotte. First it started to read 20mph when car was off now it has worked its way to 40. I was told by tech guy who is not even SW but a supplier of the gauges that i cant even send it directly to SW i have to send it through him to SW and it will cost my 30.00 in shipping cost. Probably because he has to send it to Mexico!!! What kind of customer service is that???? I dont even want their **** anymore..
  17. HOTRODPRIMER
    HOTRODPRIMER
    I hear you brother,,I have been using my Garman as a speedometer. HRP
  18. chaddilac
    chaddilac
    I agee... but if you have a hole in your dash for the new ones... you might have to open it up a bit for the older ones. They are 2 different sizes. I found that out on my dash after I was using an older sw speedo for mock-up and keeping the new one in the box so it wouldn't get scratched. Went to install all the gauges and dang it!! .25" too small on the new speedo!!!
  19. Keither
    Keither
    My speedo will not calibrate, is all over the place and even clicks off 10ths when sitting still with the ignition on. The tach is a whole other story. I have tried noise filters, independant grounds and power feeds, isolating the wires from the sender...pure junk.
