Stewart Warner tach help
Discussion in 'The Hokey Ass Message Board' started by Devin, Jul 22, 2013.
  1. Devin
    Devin
    from Napa, CA
    I wired my tach up and it doesn't seem to be doing much of anything. I'm pretty sure I wired it right:
    meter -: wired to - terminal of tach from sending unit and also to a known good ground on the body
    Meter +: wired from sending unit to + terminal on tach
    Dist. Prim: wired to - terminal on the coil and distributor
    My question is where does the unit get positive power from? I tried running a positive wire to the positive terminal on the sender and the tach needle sweeps all the way across. What am I missing here? There's only three damn wires! ImageUploadedByTJJ1374545134.850455.jpg
    Tach sender is the same as this one
  2. Devin
    Devin
    from Napa, CA
    Bueller?
  3. 26hotrod
    26hotrod
    from landis n c
    have u tried s/w web site?
  4. Devin
    Devin
    from Napa, CA
    No, I figured this is an early 60s unit. I will check. Thx
  5. badshifter
    badshifter
  6. Devin
    Devin
    from Napa, CA
  7. 327-365hp
    327-365hp
    from Mass
    Yes, they take obsolete batteries. There are many threads about these, the only fix is to have somebody like Williamson's convert them to electronic. FWIW, mine was working until I converted to Pertronix, it didn't like that.
  8. Devin
    Devin
    from Napa, CA
    Gotcha. I figured I couldn't have wired it wrong. Any DIY solutions for modern batteries etc?
  9. landseaandair
    landseaandair
    from phoenix
    Depending on the tach used, that is the sender. I've got one like it that still works but I think it's different. It has an "adjustor" access hole on top and all the ones I've seen without it look to have had batteries and are usually crusty inside.
    Here's mine for comparison.
    tlowe likes this.
  10. Devin
    Devin
    from Napa, CA
    Any idea on battery voltage?
