Technical Stewart-Warner Tach Hookup Help
Discussion in 'The Hokey Ass Message Board' started by brett4christ, Nov 4, 2017.
  1. brett4christ
    brett4christ
    I just picked up this SW Tach and I need to know what it takes to install. Does it require a sending unit? How is it wired? See photos for part number (?) or other info...
    All help appreciated!!![​IMG]
  2. brett4christ
    brett4christ
    Somebody's GOTTA know how this thing works!!!! HELP!!!
  3. tubman
    tubman
    My partner and I have been doing a lot of work with older tachometers so, although I have never seen this particular one, the 0-5000 range and the wire terminals on the back say to me that it's an older "meter-type". These tachometers usually need an external control box, although we have seen them with the controller inside the case. I'd have to have my partner (he's the electronics guru) look at this to be sure.
    The reasons we are interested in these is that there seem to be many out there with missing or non-operational control boxes. We are in the process of developing a universal controller that will allow these tachs to be used again. We have the most difficult instance (6 volt positive ground) running in a prototype state now.
    brett4christ likes this.
  4. razoo lew
    razoo lew
    from Calgary
    An old Hamb post for a 960 series tach says:
    1) no sender required
    2) isolated copper colored terminal to coil -
    3) isolated other (black?) terminal to ignition switch
    ....and I lost the post, cant reference it.
    good luck.
  5. tubman
    tubman
    We got an old Stewart Warner tach in the other day. It kinda looked like this one and it was a "meter-type" unit with the controller inside the housing. I'll check it when I go to the shop tomorrow. I'll talk to my partner and I am sure he can figure out how to hook it up. It's obviously a 12 volt unit, and it looks like it's for 4 or 6 cylinders, which is wierd; they're usually capable of running 4-6-8. You can't believe everything you read, even if its stamped on the housing. I wouldn't bother now, but if we can't figure out what you've got, it would be helpful if you could remove the unit from it's case and take a couple more pictures.
  6. tlowe
    tlowe
    Looks like that one is a direct hookup for a 6 cyl 4 cycle engine and 12V. You could test it on a V* , it will work but read incorrect.
    Is it for sale?
  7. brett4christ
    brett4christ
    Yes it is. Message me for info...
  8. Canuck
    Canuck
    This is what you need: upload_2017-12-23_17-24-19.png
    Canuck
