Stewart warner temp gauge fix.
Discussion in 'The Hokey Ass Message Board' started by ago, Jun 26, 2013.
  1. ago
    ago
    from pgh. pa.
    My 2 5/8" Stewart Warner mechanical temp gauge was reading 35 degrees low. This is how I corrected it.
    Photo #1&2 Use paint can opener to carefully uncrimp bezel.
    #3 Unscrew nut to disassemble gauge.
    #4 Can of water, heated with torch. accurate mercury thermometer (could use any known thermometer) Infrared etc.
    #5 Heat water,stir to equalize temp.
    #6 Bend kink area only with 2 needle nose pliers , to adjust gauge to thermometer reading. BE DELICATE, IT DOESN'T TAKE MUCH TO MOVE NEEDLE. increasing kink moves needle higher up scale.
    #7 After the gauge is calibrated reassemble and roll bezel back with box wrench. You can make a jig to hold gauge in lathe and tailstock and roll bezel on with a ball bearing on lathe tool.
    Ago
    Okie Pete likes this.
  2. Hotrodmyk
    Hotrodmyk
    Very interesting post. Always thought they were gonners if they didn't work right.
  3. 327-365hp
    327-365hp
    from Mass
    Awesome tech! Thank you!
  4. Eightydeuce
    Eightydeuce
    Thank you sir! I have a couple of older temp gauges that no longer read correctly, will have to try this on them. Does any one know what causes them to read incorrectly? I recently picked up a NOS Stewart Warner from 62 and it is off by 10 degrees.
  5. Fogger
    Fogger
    I've always used SW gauges in my cars since the early '60s and years ago had trouble with the accuracy of a mechanical temperature gauge. It was off 20 degrees @ 200 f. I contacted the SW rep and was told that the gauges were accurate plus or minus 10%. I sent mine to Mo-Ma in Albuquerque, 505-766-6661, for calibration. Your post is interesting and very helpful. Thanks
  6. Good info, thanks for the pics.
  7. fleetside66
    fleetside66
    Ago, are you a surgeon in your day job? I have a few junk S/W gauges & I'm going to try to remove & reinstall the bezel. I always heard it was a losing proposition to the layman. I'll let you know how I make out. By the way, how do you know that your gauge was reading low? Maybe that was the right temp? I've had four different gauges in my 283 (two electrics & two mechanicals) & they all showed different readings. I'd like to do what you did just to make my gauge read what I'd like it to read. Most excellent tutorial, by the way.
  8. That's a good fix!!
    With a bourdon-tube gauge (that's what the mechanism in your temp meter and also the pressure gauge is called), the things which s damage them most are over-ranging (a bit hard to do with a temp. gauge, but easy to do with a pressure gauge), and getting crud into the mechanism/tube (again, temp. gauges are sealed, so can't really happen, but pressure gauges, yes.)
  9. ago
    ago
    from pgh. pa.
    Fleetside, retired machinist.
    I have a 180 degree thermostat in my car and it never would read near that. So I took the bulb out of the manifold and layed it in a small tin can with water and a mercury thermometer and heated the water with a torch and compared the readings. You have to be delicate with gauges,( no all thumbs). I repaired a couple of gauges off early British bikes(Smiths). I have a book that shows you how to make a jig to roll the bezel back on with a lathe. and it works well. I will post it in the future.
    Ago
  10. ago
    ago
    from pgh. pa.
    More info on gauge bezels.
    Here is a jig for rolling the bezels back on gauge faces.
    You will need a different jig for each diameter gauge.
    Using the paint can opener to remove bezel.
    That is a bearing in lathe tool holder to roll on the bezel.
    The lathe is rotated by hand no power.
    Credit for the jig goes to Graham Blighe who authored the book
    MAGNETIC SPEEDOMETER REPAIR.
    Graham's book is only about British M/C speedos.
    Ago
  11. Jay Tyrrell
    Jay Tyrrell
    This is a great tech! Thanks for sharing.
    Jay
  12. 39 Ford
    39 Ford
    Thank You for the information, Fleetside66 and I had a talk about your post earlier today.
  13. ago
    ago
    from pgh. pa.
    How do you get this in the tech archives?
    Ago
  14. ago
    ago
    from pgh. pa.
  15. Hotrodmyk
    Hotrodmyk
    This has got to be one of the best tech topics I have read. VERY interesting. Thank you.
  16. maniac
    maniac
    Paint can opener..........:cool:
    Great tech, I only run mechanical temp gauges, I'm bookmarking this:D
  17. fleetside66
    fleetside66
    O.K., I did the lens removal thing on a mechanical water temp gauge where someone cut the line. Here are some pics. I must say that I personally found the paint can tool a bit too cumbersome, so I tried massaging it a bit smaller & sharper. It still didn't seem right to me, so I bent a small flat bladed screwdriver & that seemed to work (for me, anyway).
    It came off real nice..no tears or unevenness. Getting it back on was a bit more of a challenge. I tried the wrench head method, which worked fairly well, but I did end up using the screwdriver a bit to clean it up.
    I'm not so sure that I'd be as successful with one of the older S/W gauges (like the Wings), because I heard somewhere (maybe Travis from Morris Gauge) that the bezel is very difficult to remove & reinstall because of its inherent softness. I don't think I'll be experimenting on one of those anytime soon.
    Anyway, thanks for the post. Next I'll try the calibration thing. Actually, I think more than anything that being able to remove & replace the bezel will be good for cleaning those gauges that have all the dust underneath.
  18. Chris
    Chris
    Great thread!
  19. ago
    ago
    from pgh. pa.
    Grasshopper, I had to modify the paint can remover also, I mounted the paint can opener in the tool post of lathe. It worked a little better. We need a lot of patience with this stuff. Do you know someone with a lathe? The lathe fixtures for rolling the bezel back on work well. You nee one for every different dia. of bezel.
    Ago
  20. I've done several bezel removals and installs by hand. Must be easier with the lathe. Slow going but worth it.
    You can get a piece of wood (2x4, etc) as a holding fixture and, providing you have the correct hole saw size, drill a hole to take the front edge of the bezel and hold it steady while you open or close the edge from the back side. Gauge goes face down into the hole - helps to protect the glass too...
  21. ago
    ago
    from pgh. pa.
  22. 36tbird
    36tbird
    Gotta love the HAMB! You have an issue, go turn on the computer to see if anyone else faced the same thing, and, WALA!, there it is.
    I bought some of the current Wings gauges (Hecho en Mexico) and gonna run two mechanical temps, one for each side of the flathead. I put in 180* thermostats. Finally got the old motor started recently and both new gauges read 150 to 155. I just pulled off an upper hose to verify my thermostats and it is stamped 180.
    So both read the same low temp, apparently. At least they're standardized. Knowing this, I think I may just leave them be. I know that I don't have the steady hand required to do this sort of work.
  23. 2manycars2littletime
    Great tech; thanks for sharing.
  24. continentaljohn
    continentaljohn
    Bttt
    Great tech and have to add a bit to it.
    I machined a few grooves into some soft brass and 6061 aluminum. The grooves start at .145 and move down to .120 or a 1/8 of an inch as that’s is what my tachometer rim was originally.
    I removed the rim by using the same method as above to replace the glass . I then had to reinstalled the rim and pretty straight forward folding over the edge . I then roll the larger groove onto the chrome outer ring and it folds down the rim to the groove size. I bring the next groove slot and roll it around the gauge till it’s tight and looks good. Sorry pictures are out of order. image.jpg image.jpg image.jpg image.jpg
    Ken Smith, Speccie and Okie Pete like this.
  25. seb fontana
    seb fontana
    from ct
    Had to replace broken tach glass on my motorcycle, used replacement glass for a flashlight.. Totally destroyed bezel. I had to machine a replacement; lucky I could make it out of aluminum, being so thin it was a pain. Roll/crimped it back on in the lathe similar to above pics. Painted black like original, perfect. Took a leap of faith.
    continentaljohn likes this.
