Hot Rods Stewart Warner "wings" speedometer problem
Discussion in 'The Hokey Ass Message Board' started by johnny jackson, Nov 15, 2025.
  1. johnny jackson
    johnny jackson
    I have a new Stewart Warner mechanical speedometer, and a new cable. The car is a hot rod '37 Plymouth truck and it has a TH350 transmission. I have the cable in the transmission fine, it turns the cable with no problem. However, the end that goes into the Stewart Warner gauge is not engaging to turn the gauge; seems short or too small. I have verified that the cable turns the inner cable/wire when driving down the road, and increases at speed. However, it seems as if the cable either isn't long enough at the gauge end, or the fitting area is a little larger on the Stewart Warner gauge....anyone run into a problem like this? Thank you for all insight....(I will call Stewart Warner tech Monday, but wondering if someone has had this or a similar issue).
  2. 51504bat
    51504bat
    Ask Rusty @e1956v from Speedometer service in Colorado. Good guy, knows his stuff, and an Alliance vendor as well.
  3. johnny jackson
    johnny jackson
    61504bat, I will do that. Thank you.
  4. johnny jackson
    johnny jackson
    Here are a couple of pictures that may help...
  5. 2 nailbender
    2 nailbender
    from iowa
    I had the same problem Got a new cable problem fixed. One other way would be replace the inner cable in the old housing making a bit longer.
    05snopro440 and winduptoy like this.
  6. 05snopro440
    05snopro440
    I'm not sure of the design inside the speedometer, can you check engagement with a caliper?
  7. MMM1693
    MMM1693
  8. winduptoy
    winduptoy
    I fought a mechanical drive speedometer problem and it was the size of the male square on the end of the cable being smaller than the female square in the speedometer head....(don't go there guys)
    a trip to NAPA for a universal cable didn't fix it...just the cable that goes in the housing...
    I had to build up the cable end with some silver solder and then file a larger square....
    maybe not your problem ..... too short or two small...one of the two
  9. e1956v
    e1956v
    Alliance Vendor
    Just answered the PM
    From the pictures cable length looks ok, so as stated in a previous post the cable square size should be from .102 to .104 I have seen aftermarket cables squared down to .99 and sometimes that will just spin in the magnet.
    Sometimes you can get away with a .100 square size but that’s on the edge.
    51504bat likes this.
  10. 302GMC
    302GMC
    from Idaho
    Cable too short ? Pull the flexible inner piece out, lay it on your bench or floor & make note of the length. now, place one end in your vice & gently pull on the other end until it stretches about 3/4''. Blow out & straighten any kinks in jacket, lube w/ graphite & re-install.
  11. johnny jackson
    johnny jackson
    Thank you all for your guidance. I will be talking to Stewart Warner tech support tomorrow. Hopefully the have some solutions. If not, I will see about a different cable, modifying the cable, or if there are adapters.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    take the insides out of the cable and trial fit the square into the speedo, that way you can see what is going on
    Joe Blow and Tim like this.
  13. johnny jackson
    johnny jackson
    All, I spoke to Stewart Warner Tech. They verified that the square female end on their gauge is .104". The weren't really much help. I measure the inner depth of the gauge and it seems to be about the same as the cable part that sticks out. I am going to try another cable to see if that makes a difference.
    Tim likes this.
  14. johnny jackson
    johnny jackson
    So, I was able to get anther cable, and by chance, it seems to work. I could not discern any difference when comparing the two. It seems that there is enough play in the internal wire/line that if you push it into the Speedometer side first, you can, as long as you don't pull it out, then go into the transmission. However, it also seems like adding a shim behind the bezel that hold the line in place (on the gauge side) would move the line just enough to keep it in the gauge female orifice, permanently. Here's a picture of what I am thinking, that may help. (of course, the shim is home-made). speedometer cable.png
    TrailerTrashToo likes this.
  15. BJR
    BJR
    I have seen speedometer cables with that exact shim installed from the factory. Couldn't tell you what cars they were on though.
