Technical Stick welders, help me out please
Discussion in 'The Hokey Ass Message Board' started by Budget36, Dec 23, 2023.
  1. Budget36
    Budget36
    I don’t arc weld that often and am not really good at it, but I need to do it tomorrow.
    I can’t recall if 6011 or
    6013 was an easier rod to start the arc?
    I know one was, but 4/5 years later I don’t recall.
    The only thing I do know for sure is how to weld it once it’s burning;)
    Sharpone likes this.
  2. twenty8
    twenty8
    It would have more to do with what you are wanting to weld.
    6011 is a general purpose rod for mild steel.
    Use 6013 if it is sheet metal.
    Sharpone, Rickybop and Budget36 like this.
  3. squirrel
    AC or DC? :)
    Sharpone and Budget36 like this.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Twenty8 is correct.
    When starting an arc, be sure you tuck your rod holding arm and elbow against your side and keep it there. it gives you steadiness when striking an arc and allows you to maintain it.
    Sharpone, twenty8 and Budget36 like this.
  5. Budget36
    Budget36
    AC Miller. Will try to explain:). 1 inch thick to 1 inch thick.
    Part of a grader blade to arms from a Ridger. The arms will support the work the blade does. Ie “push it” as I’m pulling it.
    I’ve used both rods in the past, just recall one was easier to start the arc easier than the other.
    Figured I’d ask the general question instead of chipping off slag;)
  6. Mr48chev
    6011 has deeper penetration but you don't get as pretty a bead as you do with 6013.
    6011 for heavier metal, 6013 for lighter metal.
  7. Driver50x
    Driver50x
    I find 6013 much easier to start. I find that you have to use a higher amperage setting with it, because it has less penetration than 6011. Then again, I don’t usually weld anything an inch thick.
    Budget36 and Sharpone like this.
  8. tomcat11
    tomcat11
    In my younger day's I had a side job repairing heavy drill rig equipment and used mostly E7018. Low Hydrogen and higher strength. One inch thick material usually needs proper joint prep and multiple p***es.
  9. ***Area-51***
    ***Area-51***
    from Ohio
  10. twenty8
    twenty8
    "V" and fill.....
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    1” thick metal needs to be beveled.
    Start with a root p*** ie.. a thin bead to just fill the 1/8” gap needed at the root.
    Then weld single beads without weaving.
    Single beads won’t trap slag. Multi p*** all beads until your bevel is full.
    The best welder is a better grinder. Clean well between p***es.
    And above all… that thing is going to warp.
    Weld supports to prevent warpage.
    Ignore dimensions below.
    slayer, tractorguy, mario711 and 8 others like this.
  12. Sharpone
    Sharpone
    I would use 6011 for the first p*** grind smooth remove all slag and the another p*** or two with 6011 then use 7018 ac rod to finish.
    How many amps is your welder 1 inch of weld is a lot . If you could use 1/4 inch 6011 rod at around 250 amps and 3/16 inch 7018 ac rod at 250 or more amps This would help minimize the number of p***es required. Reading your post not sure if you’re welding 0.1” to 1” or 1” to 1” if welding 0.1 to 1 inch you could use 1/8 rod with good results. Back to ease of starting arc 6013 is easy welding just not as deep penetrating or generally as strong of weld as 6011. 7018 is a higher tensile strength rod and makes a good looking bead. Just my 2 cents worth.
  13. Sharpone
    Sharpone
    Yes good info. I forgot to mention the bevels and the gap for the root p***
    Petejoe likes this.
  14. dalesnyder
    dalesnyder
    6011 is what beginners will use , it is an easy rod to start with.
    The best rod I used as a newbie was cronatron 333.
  15. Sharpone
    Sharpone
    A good fast fill rod is Lincoln Jetweld 7024 makes a beautiful bead and builds fast
    bobss396 and Budget36 like this.
  16. krylon32
    krylon32
    from Nebraska
    I think back to my mid teens on the farm and my dad got a new Forney welder. I practiced and practiced and got really good. Built my first few ch***is with that stick welder. 60 years later before we moved from the farm I went out to the machine shed with some s****, fired up the Forney and about all I could do was continuously stick the rod to the s****. Decided I'd been Mig & Tig welding to long. Left the Forney behind when I moved.
    warbird1, 19Eddy30, bchctybob and 3 others like this.
  17. saltflats
    saltflats
    from Missouri
    1 inch sounds thick hope you have a good machine. Is this weld just to hold a replaceable blade?
  18. 51504bat
    51504bat
    The welder at the dairy I worked at years ago referred to 6011 as farmer rod. He used it for damn near everything.
  19. Pete1
    Pete1
    from Wa.
    For putting 2 pieces of 1 inch together V'd out 45 degrees on each plate and on a piece of heavy equipment like
    that, I would use 1/4 inch 7024 rod and run it at about 250 to 300 amps.
    The 7024 rod is an iron powder rod and will fill a lot faster than others. You can run it with a very short arc.
    warbird1, Sharpone and Budget36 like this.
  20. 38Chevy454
    38Chevy454
    6011 will run good on your AC machine. 6013 is less penetrating and may run little smoother, but I would recommend the 6011 to help ensure better weld strength. On an AC machine you need 7018AC rod if you want to go with that, which is a great choice. Std 7018 rod will not keep the arc. The 7018AC rod has arc stabilizers that help since in AC the arc is going back and forth, at 60 cycles per second. Std 7018 just won't run on AC.
    If you are really welding 1 inch thick material, do some preheating and it will help your weld penetration a lot. Hotter the better, but being 1 inch thick you will probably be limited in how hot you can get it.
  21. 1946caddy
    1946caddy
    from washington
  22. LWEL9226
    LWEL9226
    from So. Oregon
    If you can turn your project so that all the welds are flat....
    LynnW
  23. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes preheat before and during welding on that thick of material.
    Prevention of warpage
  24. Budget36
    Budget36
    Well. The Ridger holds two blades. (To make a levee ) I’m going to take the blades (basically disc blades) off and on the “arms” that held them weld the grader blade to it.
    So realistically it gets it support from the arms behind the blade, the weld will hold the blade in place.
    Was trying just to get my memory jogged on the rod.
    I do have 7018 as well for an AC machine.
    Thanks all.
    Edit: my Miller on the high side is 200 as I recall. But that won’t be a concern for this.
    Yes, the blade is 1 inch and the arms are 1x3. I’ll be welding to the narrow side on the arms, had planned to bevel them. But won’t do anything but grind the area to weld on the blade.
    It will last longer than me, heck, if I could reach things with my wire welder, I’d use it without concern.
  25. Budget36
    Budget36
    My weld will be similar to A that you posted, where the arrow on the left is pictured. Where it (arm) meets the blade, I’ll grind the edge of the arm.
    Since this will be well off the ends of the blade, preheating would be fairly tough to do.
  26. E-6011 and E-6013 have the same strength.
    E stands for electrode
    The first two numbers in stick electrode are the tensile strength 60 stands for 60,000 P.S.I.
    70 would is 70,000 P.S.I.
    The third number is weld position 1 is all position. 2 flat only
    Last number Flux type, and current
  27. Fortunateson
    Fortunateson
    Not trying to piss anyone off and I know this thread is about welding but...one inch thick material and on some industrial sounding machinery doesn’t really sound like HAMB material to me....
    Carry on before it gets noticed by the MAN!
  28. Budget36
    Budget36
    It’s all good! I didn’t want to really go in to what I was doing, it had been so long since I arc welded, I just wanted clarity on which rod started easier.
    Driver50x, Petejoe and Sharpone like this.
  29. gene-koning
    gene-koning
    Not to piss anyone off, but sometimes when you need a correct answer fast, you go to the best source for getting that answer as fast as possible. The HAMB is one of those places.
    Though the actual details are not HAMB specific (the thickness of the material) the information transfers across many HAMB friendly needs, and may provide needed info for someone on their HAMB related project.
    We are just guys helping other guys. If the topic is not of interest to you, you don't have to read it past the point where you know it doesn't apply to your narrow interests.
  30. Petejoe
    Petejoe
    from Zoar, Ohio
