Technical Sticky flathead valve
Discussion in 'The Hokey Ass Message Board' started by Joe Hook, Aug 20, 2025.
  1. Joe Hook
    Joe Hook
    I have seen this topic before I had a problem, but couldn't find it again, so here goes: My 8ba 239 has developed a misfire and back fire. Replaced dist cap, rotor and plug and coil wires, also has a new coil, new plugs, but, the back cylinder driver side plug carbons up quickly. The other plugs look OK. What fuel additive and oil additive, if any, might help to free the valves? I don't want to pull heads yet if it can be avoided.
  2. 19Fordy
    19Fordy
  3. Doublepumper
    Doublepumper
    from WA-OR, USA
    I like Marvel Mystery Oil for things like this. Put some in the fuel and the oil.
  4. jaracer
    jaracer
    Well it sounds like you have already used the parts cannon. Why not do a compression check and verify that you have a cylinder with low compression? Put some air in the cylinder and verify that you have a valve that isn't closing. That's probably the first thing I would have done. Sun Electric had a motto: "Test, Don't Guess".
    AccurateMike likes this.
