Technical stiffer front coil springs 55 ford custonline
Discussion in 'Traditional Customs' started by bignutz1, May 6, 2017.
  1. bignutz1
    bignutz1
    hey guys, i didn't think the coil springs would be an issue when i put the 351c in but i imagine they are old and weak and not use to the weight of a 351c. what kind of coil spring should i use to get the front up so as it does not rub tires on fender when i turn and where is a good place to purchase. thank you.
  2. David Gersic
    David Gersic
    from DeKalb, IL
    Call Eaton in Michigan. They can recommend something that should work, and will swap it if it doesn't.
  3. Dirty Bird Clothing Co
    Call Pohl Springs in Spokane, WA. 509-535-3648
  4. Ford Granada 1975-80 coil springs for a V8 car with factory AC will work. I have done lots of conversions in those years of Fords with the Granada springs
  5. Mark T
    Mark T
    Factory springs should be plenty strong.
    A 351c weights approximately 550 pounds, a '55 Ford Y-Block weights approximately 610 pounds
  6. bignutz1
    bignutz1
    thanks guys for the help.
  7. Kerrynzl
    Kerrynzl
    This ^ ^ ^
    Just get the original springs re-set
