Projects StNick's - 1957 Ford Custom 300 Build - Progress Begins!
Discussion in 'The Hokey Ass Message Board' started by StNick, Apr 4, 2010.
  1. "I am a precisional instrument of speed and aeromatics." - Mater
  2. 3rd member
    Plus Housing
    Axles and a drive shaft equal.....
    Drive Train!!!
    Looks GREAT!
    The Shifter is in too!
    The Carbs and air cleaner are on too.
    There's still a long list to do..
    • We need to patch the firewall and cover the heater box opening
    • Plumb Brakes
    • Plumb Fuel System
    • Mount Font Clip
    • Radiator mounting fabrication
    • Ignition, fuel pump, starter ****on wiring
    • Hood...... (Maybe)
    That is the big item short list.
    Here's a few pics of the rear tires inside the fenders!
    There's more room on the drivers side, not sure if its the body to frame mounts or the way the quarters were repaired. Either way they fit!!!!
  3. BTW.... we need some headlight trim rings. We cant seem to find the one (1) we had.
    Black or Stainless/Chrome are good.
    Thanks!
  4. KustomCars
    KustomCars
    from Minnesota
  5. OahuEli
    OahuEli
    from Hawaii
    Man I an sooo looking forward to seeing this beast hit the strip!
  6. benchseat4speed
    benchseat4speed
    from Golden, CO
    What ratio are you runnin? Is that a spool?? Lookin good man nice work good progress!! Keep it up. Later, Kevin
  7. Zapato
    Zapato
    no driveshaft safety hoop ?
  8. Not yet. But it will.
    Dude, we don't have brakes or fuel yet!
    TJJ on iPhone
  9. Dads been painting interior parts, the seats are almost done.
    Here's a shot of the axles....!
    Worked on the fuel system last night. I bought a 25' roll of steel 3/8 line.
    NIGHTMARE! that is the hardest shot to work with, can't bend it. I'm re-thinking my strategy.
    TJJ on iPhone
  10. Hans Viking Slott
    Hans Viking Slott
    from Denmark
    Wow
    that is some progress.... Sure is looking good.
    Just to let you know I am following every step from way over on the other side of the great ocean.
    Keep up the fuc.... great work Bob and Mike.
    P.S. Can't wait for the ride in that fabulous 57 Ford. -"Gently rebuild"
    Cheers from Lena and Hans (The Viking)
  11. Moser third member, 3.25:1, Tru-Trac - supposed to be the bestest newest thing!
  12. So Great to have you join the adventure!!!
    I wish you where here to help, we have a fast approaching deadline for the HAMB Drags August 18th. Cant wait for you to come take a ride in this Beast!
  13. I got a call from the upholstery guy, he needed a pattern for the rear package tray.
    Ok, Ive been working on the brakes, and with the headers there is no room for the roll control valve and the proportioning valve. So I came up with a bracket that I can weld to the frame under the drivers feet/seat.
    I got it welded and mounted late last night.
    Afterwards I started thinking that the R/C is going to have to be inline after the prop valve, so I have to re-plumb that. I think this will work.
    I also got all the rear brake lines plumbed!
    The Fuel lines are plumbed from tank to far side of pump, I need to teflon and tighten every thing up.
    Dad got all the clutch linkage off, we extended the lever an inch, he drilled the hole and painted it. Should go back in today.
    I left the shop at 11pm to do some shopping, lucky me, they had my favorite ice cream!
  14. NoSurf
    NoSurf
    Nice job on the brake bracket.
    Save me some ice cream....
  15. StNick
    StNick
    Worked most of the day - got the rear brake shoes finished up (had to pull out the old 1960 edition of Auto Repair to see which shoe went on the front and rear of the drum) - got lots of little odds and ends done - got the shifter linkage installed - got the clutch linkage hooked up - installed new needle valves in the carbs - hooked up the throttle linkage - steering arms etc all tightened up - forgot to check the motor mount bolts - best not forget them - STILL LOOKING FOR OUTER HEADLIGHT TRIM RINGS - NEED THEM FAST - finished for the night - still lots to do though - - - STNICK
  16. 65COMET
    65COMET
    Just a thought on the fuel system,you may want to use a flex connection from the pump to the hard line,it will help cancel some of the pump noise and help keep the hard line from fracturing.I like the way you mounted your brake controls. ROY.
  17. shoprat
    shoprat
    from Orange, CA
    Looks great, But I wouldn't use any teflon on fuel lines or most anything else.
  18. Nice work Dad!
    TJJ on iPhone
  19. Excellent tip!!! I had that thought!
    TJJ on iPhone
  20. Here's a sneak peak at the interior...
    StNick had to do some scrambling the last couple of weeks to get it done, it turned out really nice! I cant wait to see it in the car!!
    Today we tag teamed, I took to the brake lines, I got them all in except the ones from the MC to the prop valve. Should be easy right. If I had the headers to do over again I would have given myself a little more room on the firewall clearance. I'm not sure where I'm going to run them yet. They might go through the fire wall and out the floor? I'm just concerned with the heat.
    Dad got the the fancy dash put together, it is super sweet with all the SW gauges!!
    All the lights wired too!!
    I just left the shop to get the kids home and to bed, StNick is working on the EZ wiring harness..... AWESOME!!
    I cant wait to hear this baby!!!!!!!!!!!
  21. Sitting at my desk, eating my B&J Oatmeal Cookie Crunch ice cream adding another post from an awesome day! Thanks to my friend Aaron for so much help with the wiring and keeping us on track! Lots of progress today!
    No KKOA.
    No Bonneville.
    It's HAMB DRAGS or Bust with this Custom 300, StNick and the boys.
    Wiring, Brake Lines, Welding, Fuel Lines, and more lists all day!
    A little preface before the following video....
    The local"Coffee Clutch" crew comes to StNick's bachelor kitchen table every morning to get away from their wives. Its kind of like the doughnut shop without the carbs. Well these rascals have been heckling him for some years now, "We'll never see that thing burn rubber"
    StNick hasn't ever had the experience of a Hurst Roll Control. After I explained it, I made a suggestion, give them an early morning visit, pre-coffee hours, pull on to the driveway slab and "CLICK"........ errrrrRRRREEEEECCCCHHHHHHHHHHHHHH!!!!!!
    He was "in Stiches" over it, we were both in tears laughing about the burn outs he can lay on his friends.
    Today I thought I'd try to recapture a little of that hysteria...
    Who's the funny guy behind the camera.....?
  22. NoSurf
    NoSurf
  23. Woogeroo
    Woogeroo
    from USA
    build boys, build!
    -W
  24. hiboy32
    hiboy32
    from Omaha, NE
    keep going guys. thanks for the letting us tag along
  25. You guys rock! Hurry up!
  26. shoprat
    shoprat
    from Orange, CA
    Nice work, and lots of it!
  27. BIG day!!
    I worked on the battery box, got it mounted and battery cables hooked up!
    StNick worked on wiring, the dash, and the tach(s)
    Roll Control - Line Loc light (OLD School light!)
    We tested the fuel pump, volt meter and the fuel gauge, they work!
    I think he was feeling a bit proud, he had to comb his hair....
    and mane..
    Our friend Avery came by looking to help...
    "You missed a spot"
    AWESOME
    Say Cheese....
  28. I need a new one.... the flex aint flexy any more!
    Go Dog Go...... we'z a goin!!!
    WOOT WOOT.... I hear the train a comin' comin round the bend, aint seen the sunshine since I dont know when....
    Motley Crue style!!!
    Thanks..... gotta sleep!
  29. NoSurf
    NoSurf
    What's left?
    Hang front sheetmetal?
    Finish wiring?
