Stock 1940 Ford Colors
Discussion in 'The Hokey Ass Message Board' started by nitrobrother, Jan 22, 2013.
  1. nitrobrother
    nitrobrother
  2. HOTRODPRIMER
    HOTRODPRIMER
  3. Pewsplace
    Pewsplace
    The three colors are very similar and vary by mfg. Mandarin Maroon is the most common on the cars and looks the best in my mind. It is hard to tell the difference in photos.The one on the left is Garnet and the second one is Mandarin.
  4. Tnomoldw
    Tnomoldw
    :)Here in the order you listed, Claret Maroon, Garnet Maroon, and Mandarin Maroon. Bill aka Tnomoldw:D
    Hey, I like the color of your car there, man. What’s that supposed to be? Sorta a cross between Piss Yellow and Puke Green, ain’t it?
    John: Well, you call that a paint job but it’s pretty ugly. I’ll betcha you gotta sneak up on the pumps just to get a little air in your tires.:eek::D
    <!-- / message --><!-- sig -->
  5. nitrobrother
    nitrobrother
    Found this shot of Garnet Maroon...I like it.
  6. tb33anda3rd
    tb33anda3rd
    if you are choosing a color for your car, buy a small amount of each of the colors and do a spray out. put the color out in different lighting. if you don't want to waste the paint use it for the first coat or an underside that will be hidden. manufacturers all seam to mix old colors a little different so it is good to do a spray out.
  7. stillrunners
    stillrunners
    from dallas
    would those be the same for 1939 Ford ?
  8. nitrobrother
    nitrobrother
    Here are the '39 colors from the same site, but the "Bright Coach Maroon" chip looks wrong...
